SOURCE: different sim card into a sidekick
if you are using the same carrier you can, just change the sim card to the sidekick and you should be fine.
SOURCE: sidekick lx screen is broke but all the lights work
how do repair the scratches on the side of the sidekick by the lights?
SOURCE: some letters on my tmobile sidekick lx phone dont work what can i do??
try do a soft reset
@ 1 0
and also you might would want to
run some diagnostics test.
menu>>setting>>system info>> menu+shift+D
to find out which is not work. so, that way
you will know what you can do about it.
such as call Customer Care to get a replacement or
take it in a repair shop to fix it for a decent place.
-good luck and please dont forget
to rate it as well.
thanks.
SOURCE: there is nothin appear on da screen of my Sidekick LX 2007
it is a flex issue, you need to check or most likely, replace it.
