SOURCE: Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
SOURCE: my toshiba laptop blank screen
hi try using ur vga port to output to a moniter if this works ur inverter is knackered if not maybe screen graphics or inverter.
SOURCE: acer aspire 5100 blank screen
Try reseating the RAM modules. If that doesn't work test the RAM in another laptop. If nothing works chances are you have a faulty motherboard.
SOURCE: Compaq Presario V6000 screen goes blank after Windows Welcome
1st it could be virus or it could be monitors bad how to find need to hook it to out side monitor and test then get back to me lala linda
SOURCE: screen black but led lights on hp g71
It may be a hardware error. Call HP and see about your warranty.
A lot of HP's new laptops have hardware defects, which could happen at any time from the day you buy it. Have it sent in and have it repaired for free.
