Here's a list of problems that have been happening. *The oven will display "locked". The oven will not work. -the door can still open and close -the lever is not the problem because it is still able to move to both the on and off position. (lever is manual) Broiler works awesome. Bake won't rise pass 170 degrees. -the bake element is fine. -sensor still works Clock will change the time -sometimes we will notice that the clock on the stove has changed time. I'm thinking the clock/ control board is the problem. Calling the repair guy is on my back burner - right after buying a new oven. Why? Because one they all charge for the initial coming out, we pay for the part(s), and we pay for every hour they are here. Wouldn't be to bad if the prices weren't so high. I'd rather buy the parts and fix it myself. Did so just this year with my fridge. Would of cost us a bunch for a simple fix. Sorry to be long winded but I just want a second opinion before I moved on to my next option. Aloha and Mahalo for all your help (goodbye and thank you) -moana
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
SOURCE: change time on stove held clock button and got a 5Ab & can't chng
Loof for the tech. sheet in the unit , either in the control panel [top] or the bottom under the drawer. It should tell you how to enter different modes on your range.
Phil
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
Hello
& Welcome to FixYa
First,
unplug it for 30 minutes and if the problem returns then it means that the door
lock assembly is bad & needs replacement. Please get back to me if you have
any other questions.
Kevin
