Worked fine until i moved it, now its tripping the breaker on power up unless i open one of the doors. It will trip the breaker as soon as i close the door.
SOURCE: Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
