Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
A
Anonymous Posted on Apr 06, 2013
Manual for stramm digital electronic safe manual
I need manual to get code to open safe
Steve Pence
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 20, 2014
Steve Pence
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9400
Points
The Stramm safe we have is a small one that we use to store keys for our drivers. To change the combination, open the safe with the current combination. Sorry, can't help you if you don't know that. Inside the door is a plastic panel covering the batteries. Pinch the plastic catch at the top and open the panel. There is a small red button which you can press to change the combination. When you press it, you will hear a double beep. Enter your desired new combination. The trick is that the last digit must be either an "A" or a "B" which signals the end of your combination. For example, if you want your new combination to be 123456, you can't do that. The closest you can come is 123456A or 123456B. Hope this helps. Steve, Mbeya, Tanzania
Lehlohonolo lethale
Level 1:
New Friend:
  • Posted on Mar 17, 2016
Lehlohonolo lethale
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9400
Points
Write your answer...the battries of my safe are flat, how can I open it manually with its keys
  • Anonymous Dec 14, 2021
    There is a square cover Infront use the key to manually open or overide the code. Replace the battery after you can set the code
3 Related Answers
Anonymous
  • Posted on Nov 28, 2009
SOURCE: change code
Try this
Open the safe.
press the red button on inside of door
entry the new code you want followed by B
Should be good
Anonymous
  • Posted on Jul 15, 2009
SOURCE: i have a gordon digital electronic safe # P45891,
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
14helpful
2answers
5helpful
2answers
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
228helpful
10answers
Forgot pin code to unlock my hardline digital safe
I have pin code but batteries went flat while I was on holiday, how do I unlock my Hardline digital safe? I do not have override key
Top Safe International Locks & Locksmithing Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
