EA - Electronic Arts Need For Speed: Carbon Logo
Posted on Apr 06, 2013
I want the product code for need for speed most wanted 2
How can you wire a 2 speed motor to run only on high
You dont really need to change anything ... just keep it in high speed. If you really want to remove the switch, remove the cover, follow the wires and comlete the circuit that is for the high speed setting. You will need a volt meter with contunity setting to complete this task.
2answers
Need for speed carbon cd key
R u want Game Product CD key.?leave all tension and use the CD Image.. ISO
1helpful
I have been given a acer aspire L320 BUT THERE IS NOT A PROCESSOR IN IT. what i want to know is what processor fits.it
The Acer Aspire L320 can take 3 different processors
1. Intel Core 2 Duo
Dual Core chip with speeds from 1.8Ghz to 3.3 Ghz
2. Intel Celeron D
Dual Core chip with speeds from 1.6Ghz to 2.7Ghz
3. Intel Pentium 4
Single core chip with speeds from 1.3Ghz to 3.8Ghz
The Core 2 Duo 3.3 Ghz is the most expensive and Pentium 4 1.3 Ghz the cheapest.
Some more information is available on the Intel website, links are below:
http://www.intel.com/products/processor/core2duo/mobile/index.htm
http://www.intel.com/products/processor/pentium_dual-core/specs.htm
Hope this helps. Thanks for using Fixya.
1helpful
3answers
How do i reprogram my speeddial numbers on jazz 4400?
Although I've been unable to locate a User Manual specific to your phone, the following information pertains to programming most all NorStar phones:
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
To Change the Contrast of the Display:
1. Dial the Feature button, then * 7
2. Press the number keys 1 - 9 to your desired brightness level
3. Press the OK softkey
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 - 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.)
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94. that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
Additional information about NorStar phones can be found by clicking here:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
1helpful
Hi, Can you help me? The assisted live where my Mother is, told her she can only go at a level 2 speed. Is it possible to limit the speed to a level 2 on her scooter as she wants to go faster, and they may...
Yep but you will have to find a provider or tech in your area that has a PP1 programmer. With the programmer he can set the top speed as low as you want and this will limit the speed even if mom has the speed pot turned all the way up. I had to do this for a lady who kept knocking all the knobs off the kitchen cabinets lo Good luck Hope this helps
5helpful
4answers
I want product key for windows xp professionals service pack 2
i have genuine product key for windows xp
THMPV 77D6F 94376 8HGKG VRDRQ
2helpful
NFS Hot Pursuit 2 Reg Code
If NFS was installed previously on your system, then the key may still be in your registry. Use regedit to find it. BUT, you can also use a product key finder to do the work for you. Magical Jelly Bean Keyfinder is the best one.
Hank
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
4helpful
3answers
Tom tom go 300 product code lost
Im slightly confused???
what was it you need your product code for?
You brought new maps, that need a product code to install?
Now tomtom say you need to buy new maps to get a new product code?
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
