Question about Sony KP-51WS500 51" Rear Projection Television
Television picture will not turn on, stays in warm-up/standbye mode, red light flashed 6x's pauses and continues...Sony KP-51WS500 51 in. Rear Projection Television
  • Sony Master
  • 8,617 Answers
6 blinks is indicating that the flyback has failed and will need replacement. You can get the flyback for that model at www.tvrepairworld.com
Posted on Apr 06, 2013
SOURCE:
  • 51 Answers
SOURCE: Sony KP-57WS500 57 in. Rear Projection Television
Hi Guys
Your problem here has to do with the amount of aging that happens to the three colour tubes - red, green and blue.
Blue actually ages slower than red and green. What actually happens is the green tube deteriorates and due to green being the predominant colour for brightness causes the blue tube`s flyback lines to appear - especially when switching between inputs or when the video is blanked.
No replacing the blue tube will not solve your problem as the tube is actually the best one of the three.
As someone mentioned there is a way to adjust this by removing the speaker grill assembly in front of the set. Doing the service mode adjustment with the remote is not the right way to solve the problem - you would be adjusting the colour gain and off-set values and would seriously be compromising the white balance of the set.
On the left hand side behind the speaker cover you will see a black square block with six adjustment points. Look for the one marked SCR BLUE, Switch the set to a unused input so the blue lines become visible. Now adjust the BLUE point counter clockwise until the lines disappear. A small adjustment should do it, Switch back to a picture and make sure the whites are still white.
This should sort your problem. I would however suggest asking a Sony service centre to do this for you. This is a dangerous thing to do as you will be working close to the 35Kv supply the the anodes of the three tubes.
I hope this answers your question.
Goo luck.
Posted on Mar 08, 2008
SOURCE: Sony KP-61HS10 61 in. Rear Projection Television
my tv has the same problem but it blinks five time with no picture but good sound
Posted on Aug 01, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Posted on Dec 05, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a sony KP-57WV600
Let me know when TV warms up does it go to standby?
If yes, standby light would be blinking, let me know how many times it blinks?
And if TV does not go to standby mode, does picture remain with red tone?
Posted on Dec 06, 2008
SOURCE: the tv just randomly turns off by itself
I have an RCA big screen older model television/I started with the same problem then the tv will no longer come on. Blinks 3 times and makes a fuzzing noise then does not come on.
Posted on Mar 12, 2009
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
Sound comes on, but know picture then unit shuts off. Standbye light blinking 10 times pause then cont. 10- kp51ws520
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.good luck
shaun
Aug 26, 2009 | Sony KP-51WS520 51" Rear Projection...
I have a sony KP-57WV600 Big Screen Rear projection television. The problem is this: When I first turn the tv on the picture is fine, than after it warms up- the screen turns red. What would the problem...
Dec 06, 2008 | Sony KP-57WV600 57" Rear Projection...
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53S63 problem
how many blinks pause then blink?
Mar 17, 2008 | Sony KP-53S65 53" Rear Projection...
No picture
does the red light give you a blinking code pause then code?
Sep 13, 2007 | Sony KP-53HS10 TV
Sony KP-51WS500 51" Rear Projection Television Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
