First off....alwys, always apply a very thin film of thermal grease to the cooler and Proc. This grease is designed to fill in the microscopic grooves and holes in the material. Do not glob it on thick, it doesn't work that way.
Case design has something to do with cooling but you are experiencing higher than normal stock temps, the more fans the better, you want some pushing air in the front and pulling it out the back, a good flow across all the hardware is essential. Installing a good processor cooler may require you to remove the motherboard so you can get to the back of the board to mount the cooler retainer plate, but there are other coolers that do not require this. If it were up to me, I would deffinately take the time and remove the motherboard and do this right. You need to get those temps down. I personally like this one....
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118003
Not too expensive and does a great job for the LGA775 socket.
For cases...I always use HAF932s...they have everything that is needed and are tool less.
