Dirt Devil Extreme Quick Vac - Wife was using the vacuum and it just shut off and won't turn back on. Breakers are not blown.
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
///////can not remove floor piece to use dirt devil versa as hand vac
My wife was vacuuming and it shut off. I cleaned the entire unit but it still won't turn on.
