SOURCE: tag link chronograph
It sounds like the button is not making contact with the movement curcit board. Take it to a watchmaker who has a pressure tester so he can look and see if in fact this is the problem, and then can re-seal your watch to the exact number of meters your watch can go diving to.
SOURCE: Need instruction booklet for Tag Heuer Classic Chronograph 2000
PDF Manuals at
Normal
0
0
11.1282
0
0
0
www.tagheuer.com
Do a search for Tag Heurer manuals
SOURCE: My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
