I HAVE A SONY VAIO VGN-FJ1S, WHEN I BOOT UP FINE WITH SONY LOGO, THEN THE SCREEN GOES WHITE, LIKE DRIPPING EFFECT, AND SOMETIMES THE WHEN U REBOOT THE WRITTING ON THE SONY LOGO IS PIXLATED LIKE A GHOSTING EFFECT, IS THIS A MEMORY PROBLE????
I actually did have a problem that was similar the screen would lighten up after a min or so and moving the screen fixed it. The actual cause of the problem was a loose chip on the circuit board of the LCD, i re soldered it to fix it, could also be a bad LCD cable.
This problem is related to defective LCD output. You can connect your Laptop to external LCD and check. IF the same problem occures then the on-board LCD is bad. IF not then the LCD itself is bad.
NOT TO SURE COS IT MY SISTER, AND IAM GONA LOOK AT IT. BUT I THOUGHT I ASK U KIND PEOPLE 1ST/? JUST ON THE LCD, IS IT THE INVERTER ON THE WAY OUT U RECON??
OR MEMORY,
OR MEMORY MODUAL???
bootup ok, then when widows is up., screens starts to slowly, blur out . matrix white dits, and wen u move the screen back and fourh screen corrects it self, but wen its happening, the mouse stops working, any connection/??
want let me toggle onto an external monitor no display fn and f7.
it happen during or when windows is up???? can it be faulty screen, or ribbon connection, or is it a graphic card issue. why cant i get a output on the external screen am i doing something wrong/??
the system in now not powring up, just a sqearl noise from the spu, any ideeal plz/#/
vgn-fj1s
3 light come on, cap, scroll. num?
The screens goes white on start-up and it does not work from an external monitor
If there is pixlation then it typically should not be an inverter issue, this kinda points to the video card if the problem happens before windows. Also does movement of the screen cause any of these issues?
Does the same thing happen with an external monitor?
