Question about Onkyo TX-SR606 Receiver
My Onkyo tx-sr606 7.1 receiver turns off by itself
My Onkyo tx-sr606 7.1 channels receiver keeps on turning off by itself. I followed the troubleshooting guide by ''booting'' and it stills turn off by itself, it just would not ''stay on''. The manual says to contact the technical representative. I am afraid that I have a ''bad'' receiver. I just bought it about 6 months ago. Please help...
  • 2 more comments
  • Izzy1967 Apr 06, 2009
    my 606 is doing the same thing.. If the volume is 30 or higher after 15 min the unit shuts down. I will try what was sugested by Mingkong. I will let everyone know how I make out
  • jlach1 Apr 13, 2009
    My 606 goes into stand-by mode when either the tv volume or the reciever volume is turned up past 53. I got this reciever 4 months ago and it worked fine when it was hooked up to my old 27" Sony Wega.
    Last week I bought a new Sony Bravia 46" lcd model # KDL40Z4100S. I hooked up the hdmi cable and also the component video cable and audio cable as per the Onkyo instruction manual. this is when I started to have this problem. Would hooking up the hdmi cable when I don't have a subscription to hi def from my cable provider have anything to do with this problem? I don't think it's the av reciever since it worked perfectly with my old tv, and I could crank up the volume as much as I could stand. Please Help!!
    JoeL
  • nice08 May 05, 2009
    the receiver turns off by itself and the standby mode light keep on flashing.
  • jlach1 May 11, 2010
    I contacted Onkyo customer service and had them walk me through a trouble shoot session. I disconnected every component and all speakers. I then reconnected each speaker seperately and turned the volume up to the max. The reciever worked perfectly. I then reconnected each a/v component and tested them seperately. Everyone of them worked perfectly on max volume. I then connected everything and watched the TV. No problems. I then played a dvd, no problem. This worked for about 2 weeks, and now I notice that the problem has reappeared, although I can turn the volume to about 50. I don't think it's a problem with the reciever. This could be a TV related problem.
  • 17 Answers
Hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
    New Friend:
    Problem Solver:
  • 5 Answers
I had this problem, and it was one of the speakers. I disconnected the right rear speaker and now it works fine. I asked a guy at Visions how to solve it so I can hook my speaker back up and he said that banana plugs prevent wires from crossing and sending a backwards signal (causing the receiver to turn itself off). Hope that helps!
Posted on Dec 20, 2009
  • 3 Answers
As well as the excellent advice given - instead of unplugging stuff - you could run the set up mic with the 606 and it will "sense" if any speakers are not properly connected.
Posted on May 19, 2009
    Genius:
  • Onkyo Master
  • 1,550 Answers
Maybe by mistake you burn the audio amplifier IC
Posted on Mar 06, 2009
SOURCE:
Onkyo 545 one channel don't work
Use headphones or Computer Speakers
and plug in to your headphones jack.
If the audio is present on both channel , check your speaker system
or the jack circuits.
If symptoms are the same, follow the troubleshooting on the link
above.
Oct 09, 2012 | Onkyo TX-SV545 Receiver
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
When power button turned on, receiver powers up
I have had the same problem with my new Onkyo HT-S 5305B (A/V Receiver + 5.1 speakers). To solve this, try to follow "Troubleshooting" guide that came with your system. I followed it 2-3 times. In my final attempt, when system was not shutting down but stayed-n with no sound, I played with the setup and tried changing audio adjustment, input, dimension etc. and slowly I was able to get speakers up one after the other. It's working fine now.
However, I am little concerned that why such a high-class Onkyo system failed in less than two days, forcing me to troubleshoot. - Apurva
May 10, 2010 | Onkyo TX-SR500 Receiver
I have a onkyo tx-sr506 receiver that turns it self off
This unit is in protect mode. This means that a problem was detected and the unit has shutdown to prevent further damage. The most common cause of this is failed output transistors. Plan on $20-$40 for parts for this repair.
Dan
Nov 04, 2009 | Onkyo TX-SR506 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
Tip
I hope that helps.
How to connect 6.1 speakers to 7.1 receiver
Using the Onkyo display setup, you can turn off one surround speaker, and your receiver should realize it's using the 6.1 channels instead of the 7.1
If you don't want to go that route, use the mic setup that came in the box and your Onkyo will determine by itself the 6.1 channel layout.
It should work fine.
Nov 14, 2008 | Onkyo TX-SR605 Receiver
Tip
Onkyo RC-682M Remote Codes
Download Onkyo RC-682M Remote Codes
Have you misplaced your Onkyo RC-682M Remote Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo RC-682M Remote Users Guide?
I hope that helps.
Tip
Download Onkyo TX-SR304 Manual
Download Onkyo TX-SR304 Receiver Users Manual
Have you misplaced your Pioneer Download Onkyo TX-SR304 Receiver Owners Manual?
Would you like a digital, searchable, pdf version of the Download Onkyo TX-SR304 Receiver Users Guide?
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR304 Receiver
Onkyo TX-SR606 Receiver Logo
12,131 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
