Question about Toshiba 65HM167 65" Projection Television
How to fix my 65" toshiba white pixel problem
I have white pixel spots all over My screen. It started in upper right corner and has now spread over the whole screen the spots are stationary and never seem to change only get more of them. Help!
  • Toshiba Master
  • 8,617 Answers
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
Posted on Apr 06, 2013
SOURCE:
  • 192 Answers
SOURCE: screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Posted on Dec 12, 2006
  • 346 Answers
SOURCE: toshiba 40h80 picture problem
replace c449 and also the damper diode
Posted on Nov 19, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba Projection Picture discoloration
burn in on one of the tubes try magic focus?
Posted on Dec 18, 2007
  • 18 Answers
SOURCE: convergence problems
Well I would say the convergence amps are the culpits in your case. A common problem with all rear projection sets these days. Be real careful about buying replacements as I would go OEM only. They sell counterfits and low cost knock offs that will just frustrate you and raise the chances of damaging the board.
Posted on Dec 27, 2007
  • 84 Answers
SOURCE: White spots are appearing on toshiba 65 m167 had
White spotting is caused by a defect in the optical engine. Repair should run around $600-750 from a servicer. Part number is 75006693
Bill W
integrityhomeworx.com
Posted on Mar 14, 2011
Fix a lot of white spots on mit65dlp serial wd65737
The white spots are pixels that are burned out. They will just gradually get worse. You will need a new screen or just replace the whole TV. Probably buy a new one for what it will cost to get a new screen put in it.
Nov 29, 2014 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
Dark spots on the screen of my netbook
seems dead pixel spreading . run test pixel sofware to find error
Apr 01, 2010 | ASUS Eee PC 1000H Laptop
Black spots on screen in the top corner and bottem of screen
how big are the black spots? are they pixel size? i have one black spot too but its called a "dead pixel" when ya buy laptops these days, sometimes...they will have a dead pixel gaurentee for like 25 dollars, but i didnt choose that so now im stuck with one annoying dead pixel on my 5 thousand dollar laptop but im fine with it i guess. when my screen gets bad, im rich enough to just replace the whole screen anyway. dead pixels cant be fixed i dont think just replaced by the whole screen.
Dec 25, 2009 | Toshiba Computers & Internet
Screen has black spot in corner that spreads to entire screen
one of the floresant bulbs has fail there is a place in Haverhill Ma called Tops Electronics that can fix you up really quick but you will have to ship it to them they do good work there
their new name is pinnacle solutions group over 30 year serviceing
Sep 18, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Water spill on my AOC2216Vw LCD Monitor
Hey man, thanks for coming to me. Um yea, massaging may help but too hard will do damage since it is LCD is Liquid Crystal Display and it is fragile and easy to damage. The water should clear up in a few months, if not i would look at replacing it which can be costly. Here is a link to fix your unstuck pixels
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor]
Now im not liking that bit about how you mentioned was spreading so leave it for about two days, give the therapy for the screen a try and let me know if the laptop screen is healing. For the moment if you have one i recommend you hook up a VGA Monitor, old school stuff if you can and give the LCD a rest. I will post as a solution but comment back and i will keep helping you as much as you need it.
Dec 21, 2008 | Computers & Internet
Bluish hazy texture on my screen
It sound like the light engine is going out or already out. I would take it to a certified Hitachi dealer have them check it out then I would call Hitachi to have them fix it for free.
Nov 14, 2008 | Hitachi 50VS69 50" Projection HDTV
Cluster of stuck pixels
sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Jul 28, 2006 | Toshiba 20AF43 20" TV
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Toshiba 65HM167 65" Projection Television Logo
183 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
