Question about Pride Mobility Revo 3 Wheel Electric Scooter Floor Sample
How in the sam hill do I connect the rear end to the platform of the scooter. There must be an easy way to do it. Please tell me
    New Friend:
This is the owners manual and it will tell you everything you need to know
http://www.pridemobility.com/pdf/Owners_Manuals/INTL_Scooter/uk/UK_Revo_om.pdf
all pride mobility scooters manuals can be found here: http://www.pridemobility.com/international/UK/ukownersmanuals.asp
Posted on Apr 06, 2013
SOURCE:
High pitch noise when going up hill
In your manual it will tell you what grade of slope the the Scooter will safely go up. If the slope is too great the motor will have too much of a load, and the controller will a over current situation and shut down. squealing noise may have to do with transaxle its self than the Motor Brake. The gears in the transaxle could make the squeal noise.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 02, 2016 | Health & Beauty
Thread stripped in main casting where rear section connects to front section
hi ,sadly i don't any spares at present but would advise you to look at eBay where they being sold at low prices....at times...
Regards
Rob
www.gewizrepairs.co.uk
Jan 27, 2014 | Tzora ELITE Elite Easy Travel Scooter
Main connection between front and rear sections casting broken??
hi in the uk i think that scooter is know as the http://www.aquasoothe.com/ now as it seems are you are USA ??
is it possible for a photo of the bottom part(s) as i do have second hand spares..
Regards
Rob
Jan 05, 2014 | Tzora ELITE Elite Easy Travel Scooter
I HAVE AN UTRAX SCOOTERR, 6 YEARS OLD, JUST REPLACED THE BATTERIES. THE SCOOTER RAN FOR 15 MINUTES THEN STOPPED SUDDENLY. HIT THE RESET AND RAN FOR ABOUT 5 MINUTES TIL A SUDDEN STOP. HIT RESET EVENTUALLY...
Hi, that is either a connection problem to the batteries or ( and ) a connection problem to the rear axle, remove the axle and you will still 4 connectors , convince your self that these connections are good..
IT could be the controller breaking down but i doubt it...
Please come back to me ..
Dec 28, 2013 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter turns on will not move; also shuts off intermittently when going forward
hi okay can you confirm that the rear axle comes away from the main body ? if so please check the connections here where the axle connects to the main frame, a big problem area on these types of scooters.
Regards
Dec 16, 2012 | Golden Technologies BUZZaround Lite...
Not sure of the year but my Super 9 that I bought new a year ago seems to slip a little and a getting a vibration may be from the belt. A Kymco dealer on the phone thinks that the mfg. puts too much grease...
Looks like your torque pulley, located at the rear that drives the axle/wheel has the problem.
The friction material or clutch is already worn out and started to slide. Any motor bike tech can replace it with similar part or better buy an aftermarket racing clutch w/ spring that is much better and stronger than the stock parts.
Hope that helps you out.
Thanks for asking FixYa!
Aug 06, 2011 | 2008 Kymco Super 9 LC
Rascal 600T motor gets hot.
Check the electric brake its most likely not disengaging from the motor case causing the motor to strain and overheat. You can unscrew the brake assembly from the rear of the motor and check to see if the brake pad is free and moveable If you can support the rear wheels off the ground and engage the throttle you should be able to hear and see the brake pad release. You can drive the scooter with the brake off the motor but do not disconnect the brake wiring. The scooter looks for that connection to work if it can't find the brake then it will flash and won't operate. now if you do hang the brake off the motor remember you do not have brakes and the scooter can roll backwards when going up ramps or on hills. You will have to replace the brake assembly and reattach it to the motor to have brakes
Hope this helps you
Apr 05, 2011 | Health & Beauty
Celebrity XL4, when going up hill, power cuts out. turn key off and back on, scooter will go again for a couple of feet.
Sounds like Overload Cutout ??? Use a Higher Rating Cutout, as going up hill is very hard on Scooters and it also depends on your weight.
Gerry
Aug 11, 2010 | Pride New Mobility Victory XL 4 Wheel...
1990 d150 needs rear end.
I would stick to using a Dodge rear end as there may be sensors and other connecting items that may not be the same between major brands.....Someone at the salvage yard should be able to tell you what years would interchange with the 1990 you have. I would change out the whole rear end as it is relatively easy once you get the leaf spring hanger bolts undone.
Feb 02, 2018 | 1990 Dodge Ram
Pride Mobility Revo 3 Wheel Electric Scooter Floor Sample Logo
119 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
