RCA RP5010 Digital Voice Recorder Logo
Posted on Apr 05, 2013
RP5010A RCA recorder - RCA RP5010 Digital Voice Recorder
1helpful
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
I have rca recorder rp5120-a. i have deleted everything but it still says full whenever i try to perform new recording. what should i do?
Try removing the batteries for 5 minutes then format or delete everything on the recorder.If that doesnt work, send it to rca for service,
Operating the RCA digital R[5011A voice recorder
Go to RCA web site, find support or download or alike. If you can find the exact model, download one or two similar then read those similar features. Try and error. that's how I got my RP5017 work
1helpful
RP5022A Handheld RCA Digital voice recorder
there is a link to a complete user's/instruction manual (PDF file) under "Product Details" here:
http://www.amazon.com/RCA-RP5010-Digital-Voice-Recorder/dp/B00006LEJ9
CD's used to record on The RCA CDRW 120 RECORDER that is compatible with my computer for the Automation System.
You are finalizing the CD after recording? After finalization they should play in all but very old CD players.
12helpful
5answers
RCA RP 5012A digital voice recorder
Here's the direct link:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000013901.pdf
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
