Last time it ran it was several nights in a row, shut it off in the morning and never got it started good again. Maybe twice it would blubber for a couple of seconds. There is power through the switch, tested that. Cranks and fires once when the key is turned back. Any ideas?
SOURCE: My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
If you are in Europe, you run 240 VAC @ 50 Hz. If you are in the U.S., you run 120 or 240 VAC both @ 60 Hz. Assuming that it's NOT an inverter generator, if your engine is running too fast or too slow, your frequency will be too high or too low which can damage sensitive electronics or electric induction motors. Apparently, you have a well controlled / monitored generator. While it is still running during those 20 seconds, I would check for your local voltage at it's output. If it is well above or below it's rated voltage, it's frequency will be out of range also, again, assuming that it's NOT an inverter generator. If it is an inverter type, you'll have to take it to a service center for adjustment. If not and the voltage is out of range, I would try adjusting the engine speed to bring it back into spec. I am in the U.S. My father in law had a craftsman 3,650 watt generator that didn't have the monitoring that yours does but it did the same thing. It would run for 20 or 30 seconds and quit. The oil was up and all looked well. I disconnected the low oil pressure switch and it ran fine. I replaced the switch the next day. I have a 7,000 watt Troy Bilt that I have wired into my house for emergencies but I bought a small, cheap Champion brand 1,400 watt generator for portable use. I brought it home and fired it up and out of the box it was putting out 133 VAC instead of the standard 120. I turned the idle down until it read 120 VAC and it works fine as long as I don't try to run a window A/C unit or fridge. It doesn't have the guts to start the compressor but it works great for lighting, TV's or small hand tools. Good luck.
