Vtech 5867 Cordless Phone Logo
Posted on Mar 06, 2009
The phone will not stay charning
The phone will not stay charging
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
108
Points
Just remove the batteries, wait approx. 30 seconds and then re-install. Also, if you have spare batteries in the base, just swap them. Works every time.
Warranty check battery
please test the adapter first, measure the output from the adaper see what is the exactly voltage, and if the voltage is NOT there the problem can be the adapter. Otherwise if there are the problem can be battery. However use the software diagnostic coming with the computer, and use for to test the battery chargin.
God bless you
I just dont know :/
That should not be too difficult to find out. Plug the phone in the charger and the charger to the wall socket. The phone should say Charging. Even if your particular phone does not say charging, leave the devices connected to the charger. After a few hours, unplug th phone and turn it on. If it does not stay on there is no charge. If it stays on, use your phone and see how long the charge lasts. If it lasts the same amount of time as it used to, then the charging occurs normally. If the charge does not hold, then there is incomplete charging or no charging at all.
2answers
THIS MORNING MY iPAD CAN'T BE SWITCH ON, WHEN i CHARGE IT NOTHING HAPPENS, IT IS JUST "DEAD:
check your charger mabye there a hole or ripe in it. but hope its the charger and not the ipad ? I WOULD SAY TAKE IT TO THE APPLE STORE BEST WAY TO GET HELP, ITS FREE AND THEY CAN HELP YOU WITH YOUR PRODUCT.
1helpful
Phone will not stay charge for more than 1 or 2 short calls.
Dear its battery problem change your battery and its all done.
Phone does not start it stays blank it stays dead
check if it is charged or not.
if yes then there will be moisture in the phone.
the best way is to take it to repair centre before charging.
if there will be moisture inside it can harm while charging.
1helpful
My GE 27909EE1 cordless phone's batteries will not stay charged. I've replaced batteries 3 times in 6 months since I bought the phone. Help!
Well, depending on how much you use the phone will determine how long the battery stays charged. However if you not using it enough to run the battery down, my first guess is that the "charger" is the culprit and not the battery. If you have a seperate charge cradle perhaps try to charge it in there.
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
