Question about Soyo 26 in. LCD TV
Soyo tv won't change between inputs
I have a SOYO 26" TV. It will not allow my to change the input display. It is stuck on AV2. I need to switch it to PC as it is also used as a monitor in the spare bedroom. Any advice would be appreciated. I have tried a hard boot, but shooting it and putting it out of my misery has been a thought. LOL It is a good TV and everything else seems to work excellent, I just can't get it to switch between input devices.
  • Soyo Master
  • 8,617 Answers
The main board is having an issue thats why the inputs wont switch.
Posted on Apr 05, 2013
  • nofingopher
    nofingopher Apr 05, 2013
    Is there anything that I could try doing other than replacing the main board? I am asking out of desperation. I don't really use it much and don't really want to put much or any money into it if I don't have to. It is in the guest room but part of the hosue network. Without it they don't have movies, TV or music, just DVD. Is there an external box on the market that I could hook everything up to and run through the one input on the TV?
  • Sonny Berry
    Sonny Berry Apr 05, 2013
    some cable boxes have AV outputs that should work other than that a Roku box streams movies but you need a internet connection for that also some dvd players have netflix and Roku built in. Hope that helps.
SOURCE:
C-Dog
  • 84 Answers
SOURCE: remote codes
Then you go by the UL listing code and search online to see what other manufacturers make it.
C-Dog
Posted on Feb 10, 2008
  • 4 Answers
SOURCE: My Soyo DYLT032 has power but no picture or sound
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Posted on Jan 20, 2009
  • 24 Answers
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
Posted on Feb 25, 2009
  • 6 Answers
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
Posted on Jun 30, 2009
SOURCE: i need to find out the codes to use on a direct tv
soyo tv remote code is 00000
Posted on Nov 08, 2009
Where can i find the INPUT button on my soyo mt-sygwt2697nb LCD TV
Use the remote to choose the input. You can also use the menu button to find the inputs.
Sep 15, 2016 | Soyo Televison & Video
I have a soyo DYLT032D LCD tv that comes on and immediately goes to a black screen with a grey box in the corner
check your input settings on the cables make sure they are in right and the tv is on the right input otherwise you may have a bad screen
Mar 26, 2011 | Soyo DYLT032D 32 in. LCD Television
How do i get the usb port to work on my soyo tv?
Go to set up screen and there should be options, USB should be under inputs or outputs, make sure it is highlighted "ON". Hope this helps, modern tv sets usually follow the same protocall.
Sep 11, 2010 | Soyo BayOne Extreme 9-in-1 USB 2.0 5.25"...
Connecting Pc to Soyo the screen displays Not Support!
you will need a card for your tv which is quite impossible for the average jo to fit in as has to go on the inside to allow you to use VGA? really sorry but nothing governing wether tv makers tell you about it or not?
Jun 29, 2009 | Soyo 19" LCD Flat Panel Monitor
Soyo 32" tv -- says "no sync"?
change your source input to the correct video source you are using
Feb 23, 2009 | Soyo DYLT032D 32 in. LCD Television
How do i connect a dvd player to soyo atlas dylt3212 32in
you have to use the remote and hit the input button , look at the back of the tv where you plugged the cables in, it will tell you what input it is plugged into, chang your input to that one on the tv- using the input button
Jan 09, 2009 | Soyo Atlas DYLT3212 32 in. HD-Ready LCD...
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Soyo  26 in. LCD TV Logo
583 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
