Question about Insignia Televison & Video
Insignia repair black screen
The unit powers up but the screen remains black.
  • 8,617 Answers
If the audio works normally then its most likely the Inverter board. You can get the Inverter board from www.tvrepairworld.com
Posted on Apr 05, 2013
SOURCE:
If my TV acts like it is locked but is not then what is wrong with it?
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
• Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
•Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
• Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step .
Jan 08, 2013 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Color separation ~ Insignia 32" NS-LCD32
1. Unplug unit from wall for 3 minutes;
2. Press & hold Power button for 1 minute;
3. Plug in unit.
OR:
1. Unplug for 3 minutes.
2. Plug in unit.
3. HOLD Power Button as unit starts ... hold until the unit flickers on then off twice.
This effectively returns the components to factory specs, much like resetting a computer. It offers a *temporary* fix, lasting 45 minutes to hours. All depends on the unit.
Mom has an Insignia 32" with the same color separation problem, which worsens as the day progresses. Best results achieved while television is cold.
Dust in the unit could contribute to the problem ... try to keep the unit dust free as possible.
Sep 16, 2012 | Insignia NS-LCD32 LCD TV
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
Insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
May 04, 2010 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
When I transfer video from my Insignia Camcorder to my computer, the AVI video on my computer only shows a black screen. It appears to be playing in the media player but the screen remains black. I tried...
This is a codec issue and can be most easily resolved by installing the software and drivers that came with your camcorder. Alternatively, several codec packs are available for download by internet search. Insignia recommends ArcSoft MediaImpression software for editing and playback.
Jan 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Jan 05, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 03, 2010 | Insignia 37" LCD Flat-Panel HDTV
Insignia tv will not powerup
Nothing at all? Does the screen seem to go from dark black to a lighter shade of black?
If the screen appears to stay on the darker shade of black then it is broken, and needs to be sent for repair. ( ie the screen isnt powering on when the tv is and there is nothing you can do without opening it.
You might try unplugging all cables and leaving it off with no power for a day This is in effect performing a factory reset.
and this may sound stupid and patronizing but is the TV being taken out of standby mode and actually switched on?
Nick
Sep 09, 2009 | Insignia NS-LCD47HD-09 47 in. LCD TV
I have an insignia nsdsc7b09 camera and the lens comes out when I push power but the screen flashes briefly and then remains black
I had the same problem. Just use the Playback Button instead of power. Its the button with the green triangle with a square around it. You can still use the power button to turn it off but not on. I don't know why this happens with these cameras. This happened with my camera after I connected it to the computer through the USB. Power button wouldn't work after but before it was working.I emailed Insignia customer support & they didn't help at all.
Good luck
Dec 10, 2008 | Cameras
Televison & Video Logo
100 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
