H20 symbol on display screen
Pull off your washer mains cord from the wall. Turn off your wall faucet,, the valve on wall which allows water into the washer. (h2o means your washer is not receiving the most importing thing - water). Disconnect the pipes of the water from the wall. Check by opening the wall valve to see if the water flow is gud. Next fit back carefully. Then unscrew the other end of the hose/hoses at the entry point of your washer - remove the fine filters and clean out with an old tooth brush; clean inside the opening of inlet valve too carefully, check. Now re-fit the filters carefully and screw back the hoses. You are done now. It is advisable to close the wall valve when your washing is done, takes pressure off the machine valve.
Pl click if helped.....
SOURCE: hotpoint ultima wf 860
Taken from another post - just happened to me 5 mins agao so not fixed yet!......now showing F-01 (motor triac short circuit).....
F-08 heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Good luck and let me know if/when it's sorted as may give me an indication of costs etc
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
SOURCE: hotpoint washing machine aquarius super silent wf620
Dear stacey
Had a similar error message
turned out I hadnt turned the water taps on
check this and if not the problem could be the water sensor in the drum
G
SOURCE: hotpoint washing machine WF 840 displaying F-09
f09 is a communication fault on the computer board.A suggestion to you would be to unplug unit.Carefully remove and reistall each wire at board
SOURCE: symbols on a hotpoint WD23 washing machine
hello,
what this indicate is that window / door are not properly close to there position that is free ton air at 23 degree
please make sure that doors are properly close before use and also there should be no over flow of water on the panel that is control unit .
thank you.
