I am having all kinds of error codes when trying to do various things. First when i try and add a friend, or get a friends trophy info and sync my trophys I get the error code 80711008. Before I could not even get the system to do anything let alone sign in, so I disabled the media servers in the network connections as I found from a PS3 forum, this worked and allowed me to sign in, get online and download updates but I am still having this same problem. I am on the latest firmware, running a linksys router with 100% signal strength. I did see in my router control panel where I could use port fowarding and saw a few posts about how that might work but I am unsure. Help!
SOURCE: PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
SOURCE: PS3 Problems with Downloading System Updates or Game Updates
I was having the same problem with downloading demos. what i did is that I paused the download and since i had other waiting, i started on those ones. After, I was done with those ones, I retried to download it again and it worked finally. try this to see if it works for you!
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
SOURCE: ps3 error code 80711008 and wpa
OK for your WPA you can check the security key by accessing the router http://192.168.1.1
.. password is by default "admin" and username is blank...go to the
"wireless" tab and check the ssid...under "wireless security" check the
security key...if you have "wep" check the numbers in "key 1"....
now make sure that you connect to your own ssid and type the correct key...
and
you are right , you need wlan to connect to the internet
wirelessly...however , first make sure that you have internet working
through the router..if not you will have to configure the router and
for that you a computer connected to the router...
As for your IP address simple use this site http://www.ip-adress.com/ should be everything you need
SOURCE: MW2 trophies not unlocking on PS3 can do you have a patch?
I deleted all my game save data and reinstalled the game, yes the trophies come up but i completed the whole of campaign mode on veteran and i didnt get one trophy for it... Is there a way around this
