I NEED THE SIMULATION CODE TO INSTALL THE ADF UNIT
SOURCE: how to execute simulation code
You enter the service mode on this machine by holding down the "0" and "5" keys while turning on the power.
SOURCE: DELETED IMAGE IN REDUCTION MODE REDUCTION A3- A4 ONLY
you must select paper size also original size on your copier,and check indicators.
SOURCE: what is the simulation code
THIS SHOULD ONLY BE DONE IF YOU REPLACED THE DEVELOPER, OTHERWISE IT CAN DAMAGE THE DEVELOPER CURRENTLY IN THE MACHINE
turn off machine .
turn it on holding 0 and 5
when machine starts enter code 200
after about 2-5 min it will go ito adj. mode. press the enter key on the bottom of the display.
