Roger Munns Posted on Apr 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copy quality black lines
ZappaNut
Level 3:
  • Master 960 Answers
  • Posted on Apr 04, 2013
ZappaNut
Master
Level 3:
Answers
960
Questions
Helped
308595
Points
2820
Run the CLEAN mode.
or
Remove the toner cartidge and clean the rollers.This happens when you use cheap paper. The dust gets on the roller drum and grays or streeks the copies
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
Ricoh copier 5000 bad copy quality
can u upload the sample copies? just want to understand, blur, dirty, lines etc..
Attemping to copy a black and white image and either very small color or black lines appear over the image all over the copy I want printed.
In the advanced print options select the option to print in high quality greyscale. This method will solve the problem
Gestetner DSC 232SP: I purchased this copier used and it had printing ok. My color copies are coming out horrible. they are displaying a white line in the same area on page after page. Even after I ran a...
The white line or lines are NOT caused by the fuser. A defect "line" in the fuser would cause the symtom of the print rubbing off the page but not blank lines on your copy. First we need to separate your copy quality issues. This machine uses 4 drums, 4 developer units and a transfer belt. Most copy quality issues will reside in 1 or more of these units. Lets start with a few questions. 1)Are your copy quality issues ONLY on color copies? or are the black and whites poor too? 2) Are you running copies only thru the document feeder or have you made any copies from the glass?
Are you printing on the copier from your computer?
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Bad copy quality on my brother MFC-9600. I have replaced the drum unit and still have vertical lines on the copy
Its not the drum,,, the toner cartridge has the black line pathc on the photosynthetic drum and that is causing the problem. check it by taking it out and roll the drum using your finger you will notice the vertical black patch. Get the toner replaced
Poor quality copies on Canon imageRUNNER 330
the image drum needs to be replaced
thanks for rating
Top Lanier Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
