My sisters monitor running vista 32 bit will not display when i hook up a pc running windows 7 64 bit.
SOURCE: Dell E173FP monitor on Visa
HI,
Are you putting in the Dell color monitor Cd to install the monitor ?
The new computer should not require,any drivers as its plug and play
Thanks
Proton
SOURCE: Monitor Help
I had the same pink problem. In my case when I reconnected the monitor cable to the moinitor,I accedently bent a little wire in the connector. I straightened it out, reconnected it and it was able to mate with it's female counterpart and the pink went away. Hope this might help someone.
SOURCE: The monitor only displays either
It appears that your video card does not support that resolution and color depth. If you've installed all of the proper drivers from the manufacturer, re-check the maximum specs - sounds like you're looking for HD (1080) and the card can't deliver in full color (32 bit).
SOURCE: I am using VA1903wm LCD
Update your graphics card drivers to the newest ones available. That is typically caused by having the default windows driver for your graphics card. If it is a Nvidia gpu get the drivers from them, itf its an ATI/AMD get them from AMD Game. If it is neither of those Intel does some graphic cards, if its not an Intel one go to the computer manufacturers website and find your model to get drivers for it.
SOURCE: I have an old Princeton
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver
If you want to run Windows Vista on your PC, here's what it takes:
1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
DVD-ROM drive
