HP Officejet Pro L7580 All-In-One InkJet Printer Logo
LaVonne Butler Posted on Apr 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a HP Office Pro L7580, model #C8187A. I am getting white horizontal lines across my documents. The white lines appear about every two to three inches. The top portion of the letters are missing
For some reason this happens when I use black ink. If I choose to print my document with red or dark blue ink it doesn't seem to have the white lines. Also it seems to do better when I use the "Best" v. "Normal" Quality print.
Christopher
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 105 Answers
  • Posted on Nov 29, 2013
Christopher
Expert
Level 2:
New Friend:
Cheetah:
Answers
105
Questions
0
Helped
83795
Points
139
If you can't fix the problem the best thing to do would be buying a new printer. They're inexpensive now a days and they're made to break fast so you end up buying a new one anyway. Try to check the users manual in the future
Anonymous
Level 3:
  • HP Master 32,281 Answers
  • Posted on Apr 04, 2013
Anonymous
HP Master
Level 3:
Answers
32281
Questions
Helped
7905707
Points
102259
The black print head has a few blocked nozzles.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Jun 06, 2008
SOURCE: horizontal red lines when printing
Horizontal line is carriage axis , while moving its may give line if some dust or resdual ink may be on he carriage base
clean the caping station and cleaning wiper ( place where carriage rests )
if its not resolved please update sample images for same
Anonymous
  • 2985 Answers
  • Posted on Aug 20, 2008
SOURCE: hp psc 1210 vista issue: properties
Have you got the Vista driver installed.?
Vista has many driver problems and manufactuers are not addressing them
Go to HP site for a Vista driver download,
or go to www,fixyourownprinter.com/forums and put this problem there
Anonymous
  • 47 Answers
  • Posted on Dec 08, 2008
SOURCE: hp 5550dn ( I am getting a 49.2fcc and 49.4b1a error
Upgrade firmware on the printer as a first step, 49 errors are often an issue with firmware
Anonymous
  • 2120 Answers
  • Posted on Feb 01, 2009
SOURCE: horizontal lines on printed page
You need a new Toner Cartridge
Anonymous
  • 214 Answers
  • Posted on Apr 23, 2009
SOURCE: C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Hp officejet pro L7580 printer alignment failed and ink faded
Try the steps below.
Remove the Cartridges ( bottom left side of printer ) and clean the electrical ( golden contacts ) and put them back in.
Remove the Printhead ( Open the Printer cover and you will find the Carriage that moves. Lift the latch and clean the electrical contacts ( golden contacts ) with lint free cloth
Reinstall the Printhead and wait for printer to respond. IT should fix the issue.
Regards,
Sean
1helpful
2answers
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email: [email protected]
My officejet pro L7580 printer is printing horizontal black lines on my pictures. What can I do for this?
you more and likely would need new printheads, this particular printer is one of the worst HP ever produced. i have these in the shop weekly.
2answers
When printing photos, black lines appear.
Have you tried cleaning the heads? it should tell you how to in the manual.
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
2answers
2007 won't scan to Word using HP Officejet Pro L7580
unfortunately the following is from MS Word 2007 Help:
The From Scanner or Camera option for scanning documents and pictures is not available in Microsoft Office Word 2007. Instead, you can use your scanner to scan the document, and then you can save the file to your computer.
After you scan the document, you can use Microsoft Office Document Imaging to create a version of the document that you can edit.
Important The first step is to install Microsoft Office Document Imaging, which is not installed by default.
Sorry.
k24674
Grand Canyon Tech
Grand Canyon Tech
