Pentair MINIMAX NT TSI IGNITER Logo
Posted on Mar 06, 2009
Pentair Heater shuts off prematurely when warming spa
I have the spa set to 100 degrees. Prior to turning on the spa heater the water temperature is about 60 degrees. The heater warms the spa fine until the water temperature reaches about 94 degrees. At this point the heater flame shuts off for a couple minutes. The blower keeps running. The Service Heater lignt comes on. The heater flame comes back on for about 20-30 seconds. During this time the Service Heater light goes off. The flame then shuts off and the heater fan keeps blowing. The Service Heater light comes on. This keeps repeating itself for a dozen or so times until the spa reaches 100 degrees.
3 Related Answers
Anonymous
  • 90 Answers
  • Posted on Apr 20, 2009
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Anonymous
  • 990 Answers
  • Posted on Mar 29, 2010
SOURCE: Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Anonymous
  • Posted on Jul 23, 2011
SOURCE: Pentair matertemp 400,000 BTU heater cycles on & off
My pentair matertemp 400,000 BTU natural gas heater cycles on and off before reaching desired temperature. I completely cleaned the DE filter and flow should not be an issue. When running the spa the pressure is 25. When running the cleaning system (polaris pop ups) the pressure is 30. Burner fires for 80 seconds then shuts off, reignites after 53 ceconds.Any tips on what might be the issue with the heater
Have Pentair MasterTemp 400 pool heater. Starts but turns off in a few minutes. Start up code 888 then 128 then r=8, product # 460736
A dirty filter can cause low pressure and as a result, cause the heater's pressure switch to turn OFF. A dirty filter can prevent a heater from firing and it can also cause your heater to shut off before warming the water to the desired temperature.
https://www.inyopools.com/Blog/the-most-common-pool-heater-problems/
troubleshoot
https://www.youtube.com/watch?v=V8lbH-zVQ2k
I have a Starite 400 natural gas spa heater that I replaced circuit board last year and worked fine thereafter. This year when I fire up the spa, once the temperature of the water hits 100 degrees the...
Is this a stand alone water or is it run by a control panel?
If you have a control panel that turns it on then make sure the temp reading for the heater display and the other control panel are the same or within 1 degree of each other.
If it a stand alone heater woh. Onautomation controlling it, you would want to check the actual water temp of the water to see if it matches the heater readout.
If it does then you want to heat it back to 100 , once the service light comes back on, look at the back of the circuit board, most likely you will see a hL-1 or hL-2 with a red lobby next to it.
These are high limit sensors....if one of these has a red light next to it then you need to ensure proper water flow , possibly clean your filter and ensure flow.
If it persists then the issue could be internal heater parts, thermal regulator, bad bypass, failing high limit sensor.
1helpful
Have a brand new Master Temp 400K Propane with an Intellitouch and the heater shuts off at 84 degrees. Do I need to set a max temperature from the heater control panel?
If this heater has pool mode and spa mode as an option, and you need the water higher than 84 degrees, you must set it to spa mode even if it is a pool. As a regulation, these heaters come pre-set to max out at 84 degrees as a safety feature. However, in spa mode it can reach 104degrees.
3answers
Have pentair easy touch controls just installed new water temp sensor. spa is 88 degrees but master temp heater shuts off because it reads 104. what should i check? the thermistor/
If the Easy Touch is reading the correct temperature, but the heater is not - you need to double check the temperature of the pool water with a standard pool thermometer.
Other things to consider:
1) The water is traveling too slowly through the heater. If the water is heating too quickly, then it will shut it off. If it takes a while for this to occur, then this would not be the issue.
2) Thermostat/thermistor is incorrectly reading the temperature of the water prematurely shutting the system down.
Make sure you really are checking the temperature of the water and matching this temperature up with one of the two readings that you are getting. Don't just take the word of the displays on either unit.
My heater ignites and blows really hot exhaust
The water is mixed on the back side of the heater and will exit the heater at 7-11 degres hotter than it came in. This will keep people from being scalded at pool side. So what you have sounds normal.
2answers
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
1helpful
Pentair Mini-Max NT Pool Heater does not get very hot
The thermistor is a common failure on this heater. With a setting of 104 and the heater shutting off early, the sensor is bad. If you have a digital display, check the water temp with a thermometer and compare that ot the display. Odds are that they are different. The thermistor plugs into the back of the thermostat board and is a thin whire wire set or thibker yellow wire. The white wire sensors are old and most have fialed by now.
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
