Turned off the t.v. one evening turned it back on the next day, and nothing.
The fuse of the tv is always located on the main circuit board.its like mini tube light.
The projection bulb
is gone. When the red indicator light flashes, it is always the bulb. if it does not flash then the circuit board needs replacement its a costly issue to replace the board.
replace the bulb which is located internally on the ballast board side first and check out.to know if the bulb is faulty check out the filament in the bulb it will be burned out or broken in between.
the model is quite different but will give you fair idea on replacing bulb check out the link below by clicking it.
howto replace the bulb in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
The problem canb be a blown capacitor on the power board, the TV must be inspected internally and tested toroughly to find out the cause of the problem.
There can be many possibilities for this problem.please mention any more detail.as from this status it indicates that the circuit got short in between and so there is no power in the tv or its not turning on.if familiar with the technical knowlege of using multimeters and soldering irons and continuity you can check out the tv main board and power supply area but if not familiar its risky to check just get it checked at professional repair shop as its woth getting it fixed only after getting the estimated cost from the service center .
Ok, if you have preformed a hard reset by unplugging and it still isn't powering up, its usually a blown bulb that has tripped the protect mode. you will have to replace the damaged bulb before it will power up.
Please intimate model and brand of tv to check its schematic for possible solution.
Check out the fuse or check out in another power out let,
Try unplugging the set for a while and try again.
I posted my problem last month and stated that i've had it unplugged for days, then turned it back on and still nothing. I also sent you the wrong model.oops! it's actually a AKIA rear projector but not the floor model.
Iv'e tried other outlets and still nothing. But i did not know there was a fuse. Where can i find it and how do i replace it?
AKAI PT46D10
My husband is a jack of all trades and actually used the contraption that indicates if power is goning through there was a power source, but just not turning on. So if you could help me with your last solution in replacing the fuse i'd like to go with that. where is it located?
can this be fixed or replaces by ourselves or do we still need to haul it to the repair shop?
Thanks,I've been frustrated with my set due to haveing young children that like to watch cartoons.i hope we only have to replace the bulb. Nearest repair shop is over 100 miles away,again THANKS.
