ION Audio iTTUSB Turntable Logo
bethann russell Posted on Apr 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Turns too slow
I'm currently listening to a 331?3 record and it's playing too slowly..
Electric Dime
Level 3:
Master:
  • Master 434 Answers
  • Posted on May 30, 2014
Electric Dime
Master
Level 3:
Master:
Answers
434
Questions
0
Helped
101999
Points
1138
Post the make and model number of the turntable.
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
How do I record a mailbox greeting on Avaya 1408?
Hi Tourmaster,
I have these steps for you on how to do it. Hope it helps.
Mailbox Greeting While the voicemail system will play a generic greeting to caller, prompting them to leave a message, you can record your own greeting.
1. Press the key%20messages.zoom50.png MESSAGES button. Depending on how your system is configured, you may be required to enter your voicemail password and then press the Done soft key. The visual voice menu is displayed.
2.Use the up and down arrow keys to scroll to the option Greeting.
2.Press the Select soft key or OK.
3. Use the soft keys to listen to and record your mailbox greeting.
Listen
Listen to the current greeting or the new greeting just recorded.
Record
Record a new greeting. Note that the greeting must be at least 3 seconds long or the voicemail system will discard it.
More
Switch between the different sets of available soft key functions.
Submit
Submit the new recording as your mailbox greeting.
Delete
Delete your current mailbox greeting. The voicemail will use its default greeting.
Apr 28, 2014 • Avaya 1408
Pitch is off--too slow before, now too fast.
The speed is set by a synchronous motor that drives the turn table. There may be a small adjustable resistor (pot) that will do the trick.
1helpful
2answers
Califone 1030AV turntable plays slow
The usual cause is a dirty idler wheel. Clean the tire on the idler using alcohol or rubber cleaner. Make sure everything turns easily and check the height adjustment on the idler wheel. You may have to take the motor apart to clean and oil it (if not spinning freely).
2answers
Teac A 6010 reel to reel while recording my voice it echos my voice
You may be listening off tape and there is a lag of time between the record head and the play head which is what you may be concerned with. This is normal for any three head deck be it cassette or open reel.
Slowing the speed will lengthen the time of the delay and speeding it up will shorten it.
1helpful
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
2answers
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
3answers
Why is it that when i listening to songs on youtube broadcasting yourself the song keep stopping?
Youtube downloads the song in the background as you listen to it. If this process, called buffering, happens too slowly, then youtube will pause.
Make sure you aren't downloading anything in the background, otherwise you'll need to load the page, pause the video, and let it sit for a few moments before playing. Getting a faster connection can solve this problem.
If you like my solution, please vote for me.
3helpful
4answers
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
John
John
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
