Power works, Incline and speed work. No LED showing 1/4 mile track, calories, distance or time. I have taken panels off and checked all connections seem fine. Any ideas?
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
SOURCE: Just replaced the motor controller on my treadmill
You have one of three things wrong. Either a bad console, bad motor or a bad wiring harness.
If you have a flashing light on the controller when you attempt to start the machine then you more than likely have a bad motor. (this has a long warranty may be able to get one for free, check the back of your manual)
If there is no flashing light on the console then you will need to check the wire harness. This unit is known for pinching wires at the lower section where the upright connects to the lower frame. To check this you will need to remove the console. Three screws on each side and the wire harness on the right side will need to be unplugged. Then remove the right upright by removing the two bolt located on the bottom of the frame. Then do a visual inspection for pinched wires especially where the upright connects to the lower frame.
If the harness looks ok then you will more than likely have a bad console.
If you need parts you can go to http://www.iconservice.com/CustomerService/parts.do
Good Luck! Tim
SOURCE: Nordic track S3000 model 291050
First of all, here is the ONLINE USER'S MANUAL for that model:
http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=NTL29105&modelName=NORDIC+TRACK+S3000+TREADMILL&version=0&company=11&language=
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 23 of the ONLINE USER'S MANUAL for detailed instructions on how check if the unit is in DEMO MODE.
When the console is in the demo mode, the power cord can be plugged in, the key can be removed from the console, and the displays and indicators on the console will automatically light in a preset sequence, although the buttons on the console will not operate.
If a D appears in the display when the information mode is selected, press the SPEED button so the display is blank in order to return to normal mode of operation.
See page 24 of the manual for other troubleshooting procedures such as resetting the motor breaker located near the power cord connection on the treadmill.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
SOURCE: replacement circuit board
http://www.youtube.com/watch?v=23ZgWaVEQjA (sensor speed) Test. Watch this videos tips:
http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Test and see carefully the main motor, +loose cables+solder cool+bad contact+corroded terminal wires. Clean+Tight wires.Of course retight terminal fuses or breaker. And observes the videos +Tips Carefully.
Dear Sir:1) Lube the deck belt, maybe you have a deck belt worn, and need replace.2) Test the input voltage for main motor, if there are the motor need repair or replace.3) Test the output voltage from main board for input voltage motor, if there are NOT, the board is faulty.4) See the drive belt and replace it.See my personal tips for HELPsincerely. God bless you
