Some XBox games have both a 360 and original XBox version, so you can't play them on the 360. Other games simply aren't compatible. Your game may fall into one of those two groups.
hi there,hm try a reinstall maybe,have you downloaded all the latest Video Card Drivers for your card? If not,Do so and good luck.. regards,finphillips..
Only certain original xbox games are backwards compatible on the Xbox360. To see a list of which games those are you can go to www.xbox.com and search for games that are backward compatible for the 360. You may have to download something onto your xbox360 to play the old games.
This error is caused by not having the original DVD drive in
your 360.Only a professional can change
your DVD drive successfully.You will
need the original DVD drive to fix this problem.Without the original drive your Xbox won't be
playing disc based games again. A skilled professional with the original DVD
drive should be able to fix your problem.
Do you have the game installed? I've had similar problems with other games(Mass Effect being the most recent) and by reinstalling it the problem went away and i was able to progress past the load screen and the area i was stuck in.
If your console is hooked up to Xboxlive and has a Hard Drive connected to it you will automatically be prompted to update upon insertion of the original Xbox title. Your console will restart when it's ready and you should be able to play.
*If you do not have a Hard drive you cannot play original Xbox titles.* The original Xbox Memory unit will not work in Xbox360 and the original Xbox games have no access to the Xbox360 memory units.
If you have a Hard Drive but your Xbox360 is not hooked up to the internet you can either order a disc for free from Microsoft by going Here
or burn the needed information onto a disc by going Here
