You damaged pixels in the LCD screen, Camilia. The answer is No. You have to replace the LCD screen.
[There are statements made, that a warm water damp clean cloth, can be used to gently massage the 'afflicted' area. Ummm, No.
Drip ANY water inside, and Poof! Bye-bye laptop AND LCD screen.
(Yes, even with ALL power removed. To include the CMOS battery inside. { RTC battery } Water droplet/s could still be present when power is reinstalled )
Statements made about gently using a pencil eraser on the area.
Compresses the layers of the panel, and forces oil to move around.
Does NOT always work, and may damage the LCD screen further ]
http://www.newegg.com/Product/Product.aspx?Item=N82E16834131153How tough is it? Doesn't take a rocket scientist. (Sorry Gort)
It's like doing an easy puzzle.
Example using an Asus K53U laptop,
http://www.insidemylaptop.com/how-to-replace-screen-on-asus-k53u-laptop/1) ALL power is removed. Remove the AC adapter, and Battery.
2) Open the laptop. Remove the Screw Covers from the LCD Panel Bezel.
(The thin plastic frame in front of the LCD screen )
Screw Covers may be flat small pieces of plastic, or rubber covers.
Both will have a type of rubber cement on them. They are carefully removed with a pick type of instrument. (I use a computer pick)
They are then, one at a time, lightly stuck to the bezel, so they can be reused later.
Then all Philips head screws under the Screw Covers, are removed.
The LCD Panel Bezel has protrusions formed out of it's plastic body, and they surround the outside edges of the bezel. These are Tabs.
They snap into Latches, formed on the inside edge of the Display Cover.
The method to remove the LCD Panel Bezel, is to use your fingernail on the inside top edge/middle, of the bezel, and flex it slightly up away from the LCD screen. Then move your fingers along under the bezel on each side at the top, and pop the Tabs out of the Latches.
A thick guitar pick does help immensely. Use care when removing, but be aware that the bezel is made of space-age plastic. Snap, snap, snap, when the Tabs are freed from the Latches. Almost sounds like you are breaking something, and is a slightly tense situation for your first time.
Unplug the cable (Wire/s) from the screen Inverter, IF a screen Inverter is used. Usually mounted to an area at the bottom of the LCD screen.
If it does not use a CCFL for a Backlight, and uses LED's for a Backlight, it will not have a screen Inverter.
(Cold Cathode Fluorescent Lamp)
Average example of a screen Inverter,
https://www.nt-computerservices.com/index.php?main_page=product_info&cPath=76_77&products_id=235(Approximately 3 to 4 inches Long, 1/2 inch Tall )
Lay the bezel aside. The LCD screen has a metal frame around it. Looks like a thin picture frame. On each side of this frame are Brackets. The screws are removed that hold the brackets, to the LCD Screen Frame.
Then the LCD screen can be tilted forward, and Video Cable removed.
The Video Cable's connector on the LCD screen side, has two Locks on each side usually, that you depress in, in order to unlock the video cable connector, and unplug the video cable from the LCD screen.
Reverse steps to reinstall.
Note that on the example for LCD screens, just the manufacturer code number is stated, not the laptop.
Look at the back of the LCD screen you removed, and match up the correct numbers.
For additional questions please post in a Comment.
Regards,
joecoolvette
