Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
Anonymous Posted on Apr 03, 2013
I have a Jazzy 1120 When I turn it on all the battery lights flash rapidly any suggestions
Tigre Noir
Level 2:
Sergeant:
  • Expert 317 Answers
  • Posted on May 20, 2013
Tigre Noir
Expert
Level 2:
Sergeant:
Answers
317
Questions
0
Helped
143169
Points
700
How many are flashing? There are 10 lights, if all are flashing (3 red, 4 yellow, 3 green) that indicates Code 10 and high battery voltage.
5 Related Answers
oregoon
  • 175 Answers
  • Posted on Jul 09, 2009
SOURCE: have jazzy select series need to know flashing Code #9
Consult your owners manual for the flash code guide. I believe that you probably have a PG Drives Joysitck/Controller, in which case a 9 code would indicate problem with the brake system. Check the free-wheel levers by placing them in the neutral position, and then firmly placing them back in drive. Try to restart. If still flashing, you need to remove the seat and the shroud and examine the connections inside the base of the chair. The brakes are at the end of the motor, and there are thin wires coming from them back to the controller box. Inspect these wires for any damage, and follow them back to make sure any connections on the way are tight, and that the connections for all clip connections are tight.
The brake is electrically operated by a solenoid. If the solenoid has gone bad, then this will also cause a fault code. Contact your dealer for servicing this part. Good Luck.
Anonymous
  • Posted on Aug 28, 2009
SOURCE: Wiring Diagram Pride Jazzy 1120
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are two levers just under the seat at the front. Pull the forward and to right to lock position, which will release the gear so that the wheelchair can be move about without any electric power. Bear in mind though that releases the gear, still too heavy to push as normal wheelchair. Give a go, to find out for yourself.
Anonymous
  • 29 Answers
  • Posted on Sep 07, 2009
SOURCE: jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Anonymous
  • 692 Answers
  • Posted on Oct 08, 2010
SOURCE: my hand controler on my
GAdams You need to count the number of flashes. The number of flashes will give you the flash code or error code. IE: 3 flashes pause 3 flashes pause etc. = left motor short If you have your owners manual it should list the flash codes and what they mean for your chair. If not you can contact Pride Mobility @ 1-800-800-8586 and ask for Tech Support. If medicare paid for your chair the they will pay most of the repair cost. Contact the provider where you got your chair to see if they can repair it or refer you to a service Company that can. Hope this helps
Anonymous
  • 692 Answers
  • Posted on Mar 04, 2011
SOURCE: pride jazzy quantum 1420. working fine until
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
1helpful
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
Jazzy 1120
"Cuts out" is not enough info. Check all connections for tightness, full battery and light codes.
Jazzy 600 plugged into outlet. speed level lights flashes like its charging. will not move while plugged in. battery charge meter not increasing.
Hello.Visit -www.alldatasheet.com its free.Download a troubleshooter as a PDF File of your product.Save + print if you choose to your Adobe Reader.Merry Xmas,any problem,please ask again Colin.
I have a Jazzy 14 xl when plugged in the charger shows full charge and every thing lights up but when u unplug the charger it has no power
same thing as the other fellows problem Batteries!! the charger is supplying the power to light up the joystick but when not plugged in the batteries are so low they can't turn your chair on. Replace both batteries good luck Hope this helps
My hand controler on my jazzy 1120 2000 keeps blink and I can not get the chair to move the batteries are good
Jazzy battery lights will not light and the car will not move.
check there is power in the batteries, if so check all wiring for breaks loose fittings, fuse trip switch etc, failing that it may well be the controller, hope it is not that as they are not cheap.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
