Mercedes C-Class Exterior Pillar Posts Trim Set Logo
Posted on Apr 03, 2013
My phone does not connect
The car does not see my phone
Chris
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Dec 01, 2013
Chris
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
12738
Points
53
I would think that it is your phone, check all file sharing and security settings on your phone and make sure it is all "unlocked", it could just be that your vehicles blue-tooth and phone blue-tooth are just not compatible, but that is the less likely answer. Hope this Helps-
3answers
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
2answers
Bluetooth connection
You may try deleting your phone off of your car and re-pair
Why won't my galaxy Rugby GT-S5690 automatically connect to my bluetooth
Usualy, it should, But vith bluetoooth, there are so many mysteries. Try with another phone.
Dec 01, 2017 • Cell Phones
2answers
Just bought a 2008 Taurus X Sel. It does not have a manuel. The Radio/CD player has a phone symbol on it. When I press it, it says no phone connected. How do I connect a phone to it?
Most likely that is a Bluetooth connection. You need a phone capable of Bluetooth connection and it should work automatically. If you have a phone with that capability, but it is turned off, then just turn the Bluetooth in your phone on and you should be good to go. If your call phone is not Bluetooth compatible, and you happen to have a friend with a bluetooth capable phone, have your friend sit in the car and give it a shot -- if the phone button still does not work, then there might be some sort of hard-line that you have to connect, but in a late model car like a 2008, it is more likely that you just need a phone that can talk to the car.
2helpful
I need to connect a new phone to my lexus 460ls bluetooth system
Go into the information /Nav Screen and you will find an icon for phone, then settings. Click on the icon and it it will give you a connect new phone option, click on that icon and it will release a 4 digit entry code and be findable by your phone.
Next go to your phones tools or connections settings and look for Bluetooth, enbale Bluetooth, Search Bluetooth Devices/handsfree Your phone will search out the car, once found it will request the 4 digit pin code to be input and ask you to confirm "handfsree" Once confirmed the car will read out connecting...then bluetooth connection successful and the dial pad will appear on the NAV screen
If you have more than one phone connected to the car the driver will need to select the connect phone button in order to chose the phone he wishes to enable
I have 2 phones with bluetooth connections in my car (mine and my wife's). If I call my wife's phone from my car it rings on her phone but when she answers there in no connection even though the dashboard...
they cant be together cause the bluetooths interfere but they dont work because because the same thing happen to me too when you have a bluetooth connected the same phone tries to connect to the other but tries to interfere thats the problem. i hope it helps
V551 and Bluetooth car stereo
the phone itself is having a problem connecting fully with the pioneering car stereo you may need to use a motorola one
2answers
SGH-A701 Mobile bluetooth
first of all you have to have you bluetooth visibility on for it to connect to another device.
Page 90 on your manual.
Now if you are connecting to a car in which you are, leave the bluetooth enabled on your phone. You should be just able to connect to your phone when you turn the device on in the car.
(your probably driving a toyota)
If its not automatically detecting it, your toyota is the problem. when you get in the car all you really should have to do is go to connectivity on your phone, bluetooth, connect to the device.
And the toyota is probably a prius!
My phone connects automatically every time i turn the phone on.
when you set up the device, it will ask you the question.....connect automatically>? so you need to answer yes.
Let me know if there is anything more I can do.
Clint
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
