Your model the VS-60111 is the V20A chassis which doesnt have a DM board. I can assist with the issue but will need to know what the set does when you pug it into the electrical outlet and also what happens when you press power? Any lights? if so what color and is it solid light or blinking? Please respond to this same post for further assistance.
SOURCE: Mitsubishi WS 55809 Rear projection TV
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
SOURCE: blinking green light
does that idiot know english? I can't understand his comment. Learn some puncuation!!!
SOURCE: Blinking green timer light on Mitsubishi WS 55859
You can get the repair kit which has the capacitors you need plus a cd with the repair instructions and full service manual at the following link for 35.00 with free shipping. Your model is the V19 but the V21 is the same kit you need as the V19, 20 and V21 are the same DMs Just click on the repair kit catagory and you will see the V21 DM repair kit. and if you leave them a message they will include the info for the WS55859 on the CD.Heres the link.
http://servicemanuals.vstore.ca/
SOURCE: trying to replace capacitors in dm module
it is tight, and some what glued in place just pull firmly and straight up. it will come out ok.
SOURCE: No DM Board on WD-65833
The Main Board contains the DM circuitry. And you are right, this board does not fail in the way of its predecessors. What is the unit doing?
