It depends on how long you switched on.
*check to make sure that the switch is transmitting electricity if not...
*from my experience with kettles you will need a new element*Depending on the kind of kettle you are using check the power cable and the base of the kettle to make that there is contact between the kettle and the power cable.
SOURCE: The "boil/black tea" button quit
there is a 1 year warranty on this unit. In order to have it repaired you would need to contact breville at 1-866-Breville in order to have your unit repaired most likely you have an error witht the touch control and would need to send the unit in to them for the repairs to be made here is also there link that states there warranty information as well http://brevilleusasupport.com/product/bke820xl?lm_search=Breville+BKE820XL+Electric+Kettle if you have any further questions message me back Thanks Rick
SOURCE: fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Cheapest fix is to use white vinegar to disolve the building up of limestone hardness in your water. I am certain that you find it difficult to get soap to lather well, you have a bathtub ring every time you take a bath, your towels and sheets are stiff and scratchy and your lower legs itch terribly especially in the winter. You have very hard water and you need a water softener. Find a Certified Water Specialist in your Yellow Pages.
switch on with out water how long before it will come back on
