Brought new batteries but scooter will not fully charge even tho charger lights are showing fully charged scooter will only run for 30mins and dial drops very quickly
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Hi testing battery voltage will not give an accurate reading on battery condition U need a BATTERY LOAD TESTER.it will check the condition & give U a true reading on there condition ,..if batteries r good the next thing to check is the control box the charger circuit runs into the control then to the batteries if control box is faulty this could b the problem .,with youre charger not charging . LOAD TESTER AVAILABLE ON E/BAY APROX COST $35 , Cheers
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Has the scooter been stored unused for a while? If so, the batteries may have gone solid from improper maintenance. There is a gel inside the batteries that needs to have current run through it at least once a week to keep them fluid. The charger is showing a green light because it senses the batteries are full, but instead of being full of power, they are full of crud and need to be replaced again. If the batteries have been properly charged but you still cannot get power, check all your connections to make sure they are tight and that your fuses are not blown.
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
