SOURCE: need driver for MSI K9N6SGM-V pls help
I HAVE MSI K9N6SGM-V ) Motherboard Download display driver PLS GAVE ME
SOURCE: ethernet controller driver for MSI K9N6SGM-V motherboard
download it here:-)
http://driverscollection.com/?file_cid=24542326809xlelZKzpukYZUZoo
SOURCE: MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Manual
Cut and paste this into your browser. Then follow the prompts to download the manual.
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html#/?div=Manual
SOURCE: i need internet controller driver for msi k9n6sgm-v motherboard (Windows XP 32 bit)
you will have to open up your network connections click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps
http://download.cnet.com/g02-cd33-a3-rar/3000-2098_4-200366.html
http://download.cnet.com/msi-kt4v-bios-windows/3000-2098_4-10162333.html
this is an update
