Do you know for certain that the stator is bad?
Quite possible of course, but the R/R is a much more common failure.
The R/R used on later gen CBR1000 (or CBR600) is a much better device than that on your 05 1000.
Use this dianostic guide to determine if the problem is really the stator or the R/R - it applies equally to your Honda as any other bike.
http://www.triumphrat.net/speed-triple-forum/104504-charging-system-diagnostics-rectifier-regulator-upgrade.html
One very quick test you can do on your stator is to unplug it, then measure resistance from the connector going back into stator: measure from any of the three pins to the engine ground. This should NOT be short - a short crcuit is an affirmative indication of a bad stator. If open, it is not necessarily definitive of being good, but most often is the case that a 'fried' stator has teh accompanying short to ground.
Good Luck!
