The other day while using the oven, it just shut off. The range still works, the oven light works, but the digital/electronic panel that controls the oven, time, temperature is not responsive or displaying anything, and therefore the oven doesn't work either. I noticed that there's a fuse at the top of the range, but it doesn't seem to be blown. Should I call for a repair (warranty is expired) or can I fix it myself? How?
Thanks for any suggestions!
SOURCE: Frigidaire non-digital (old) Caprice top electric oven not working
Check the clock knobs the older style you had to push in to auto time them make sure the times are on the same time (stop&start) and the buttons are popped out to engage the upper oven if so post the complete Model # and i will get the manual for you
My oven control works but the digital temperature display is too dim to read.
SOURCE: Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
