Fuji FinePix S5000 Digital Camera Logo
Posted on Mar 05, 2009
I have a Fuji FinePix S5000 and the battery door catches (on the body of the camera) have broken off. Replace complete body assy??? I am sure mine is not the only one. any help appreciated.
  • 1 more comment
  • Anonymous Mar 14, 2009
    The cover/door is ok, but the small L shaped catches in the battery compartment are broken off and will not hold the door. Really broke prematurely, with no abuse?
  • Handyman Jim Apr 05, 2009
    My battery cover is broken and I need a replacement. Anyone have one of these?
  • Anonymous Apr 26, 2009
    excellent Ozwombat, that is the exact problem I have. I will try your fix, thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6966
Points
36
I had this problem also (see below).
After getting poor results with the duct tape solution, I discovered another work-around. This should work whether it is chipped lugs on the door or on the body.
Firstly I used an old camera flash bracket that screws into the tripod socket, and this holds the battery door in place quite securely. However it was too long, so I cut and filed a piece of aluminium 25mm (1") wide by 2.5mm thick to the right length (around 100mm/4") and shape, and made a hole for the bracket screw.
End result is not exactly like new, but more functional than the duct tape and does not further damage the actual cameraI have a Fuji FinePix S5000 and the battery door - 8dbdb3d.png src="/uploads/images/8dbdb3d.png" alt="8dbdb3d.png" class="h_mi" />
  • garydoran29 Dec 17, 2010
    This is the ticket . Perhaps The piece of metal could extend slightly passed the edge of the cover where little lip could be shaped on the edge to physically hold the door closed when the tripod screw is tightened . Maybe the old lady wont snap this one off . lol .
  • Anonymous Sep 17, 2012
    Dude, can you give us other link to see How's look of the camera??? I can't find in ebay other camera broken to buy it... Thanks in advance... PD. Sorry for my bad english...
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Mar 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
6951
Points
19
Thanks for the help on this page, specially the aluminum bar solution worked perfect. Except: my wife did not approve of the looks.
I bought a used (broken) S5000 from eBay and replaced the battery compartment:
Procedure:
1) Remove batteries
2) Remove memory card
3) Remove the 5 visible screws:
2 at bottom near serial number
2 near strap
1 near memory card door
4) Gently remove back part of the camera from the main body.
There are some plastic tabs below the +/- button
5) Wiggle the whole back from the camera body
6) unclip (flip the little brown flap up) connector CN205 and slide the cable out
7) remove the screw underneath that cable. It holds the battery compartment in place
8) Slide out the upper ribbon cable (connector CN204)
9) Slide out the battery compartment
10) unplug the battery power cable (one red and one white wire) from the camera
To reinstall use reverse procedure.
I tried it a few times on the broken camera first. It is not too bad, a bit of patience, a good light, reading glasses, small phillips screwdriver and tweezers will help a lot.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4743
Points
I double and tripled about 8 rubber bands around the door. It works fine .
Anonymous
Level 1:
  • Contributor 60 Answers
  • Posted on Mar 05, 2009
Anonymous
Contributor
Level 1:
Answers
60
Questions
0
Helped
19306
Points
99
You will have to explain a bit more.
I do have some spares. (UK)l
Anonymous
Level 1:
New Friend:
  • Posted on Apr 06, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4743
Points
Can find them on ebay with instructions, $50+
Remove rear camera cover, 5 tiny screws.
Remove Battery Compartment and replace.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4743
Points
Tighten a narrow cable tie around the closed flap and camera top and slide back
at the top so it wont interfere with the zoom. this will be a bit loose so remove and do 2 or 3 more clicks on the ratchet then slide back on (over flap 1st) if still loose repeat. when tight enough cut off excess cable. the ratchet end is best positioned under flap
Anonymous
Level 1:
New Friend:
  • Posted on Oct 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4743
Points
  • Fujimadman Feb 18, 2011
    I have seen many of these cameras with the same problem, and other models including the newer HS10 have flimsy lids also. This is inexcusable, I have several fuji cameras that have years of use left in them. Can the battery compartments be bought as spares?
3helpful
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Fujifilm s5000 battery door broken
g'day
i broke mine a couple of years ago and fixed it by drilling and tapping two holes to suit 6-32 x 11/4" bolts as shown in the attached photo... one of the holes had to be enlarged to suit 6mm x20 because the thread is in a very flimsy area and had stripped
BTW the battery cover doesnt have to be removed from the camera as is shown in the photo! the photo was taken after i disassembled the camera for another repair
it works well with a couple of provisos...
1- the bolt heads may get in the way of mounting the camera on some tripods without modification
2-not as quick to change the batteries
3- dont screw the bolts down too tight - or the threads will strip
before this method i made a metal plate, the same shape as the base of the camera and used the camera tripod socket to attach it... thus keeping the battery door closed [ the advantage of this was that i could drill and tap a thread to attach the lot to a tripod - and the tripod mounting hole could be ia the centreline of the lens - making panoramas easier]11_28_2011_10_48_37_am.jpg
My battery door is broken I have to put a rubber band around it to hold the batteries where can I find the battery door
Battery doors are almost impossible to find online. I'd contact Fuji by telephone to see if they retail themselves, if not, i'd try and use the broken battery door to somehow replace the elastic band.
2helpful
2answers
Hi my name is Charles. My batteries cannot stay in
See post:
http://www.fixya.com/support/t1747423-fuji_finepix_s5000_battery_door
Elastics, sticky tape etc etc does not work.
OZwombat has neat solution by making a bar attached with a screw in the tripod connection
604foxtrot replaced half the case which came form a used (broken) camera from ebay.
2answers
Fuji S5000 camera problem....The battery door will not latch because the cheap plastic retaining nipples inside the battery box have worn down/or broken. Tape will not even hold door closed! The retainers...
You could use a piece of velcro as a strap but I would start looking at ebay or other places for the parts to fix it. Sooner or later someone will sell it.
Broken battery enclosure door on Fuji Finepix S602Z
my solution was low teck . Use velcro strips to keep door closed
Broken cover on a Fuji FinePix S5000
I think it will stay closed with painters tape or gaffer tape. this type of tape is blue or black. it is strong but not super sticky. I also have the same camera. my battery cover broke after the strap got stuck on a door handle to my office and the door kinda crunched it.
Fuji FinePix S5000 Digital... Problem:
try using electric tape to secure your latch.
1helpful
Battery compartment door is ok but the teeth on the camera are broken. is this repairable?
You would have to replace the inner housing to replace the latches.
Fuji USA might have a fixed rate for this, here is the link to the support page for the S5000: FujiFilm
Battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
