One of my kids yanked on the latch and now the latch pulls half way out. If you hold the latch in it will open the door from the inside the truck.
I just joined 10 minutes ago.........I think I can help you.
Use a spoon or wide screwdriver to pop the plastic rivets that hold the interior of the door on. Takes some courage as they dont come away easily, about 8 in all.
1, Remove the window winders, by either pushing the "ring" that touches the interior till it stops and then slide the winder off the toothed stub.pop the cover off and use screwdriver/socket to remove winders.
2, Use old eating knife or wide bladed screwdriver around edge if soft interior of door and pry/pop the hidden plastic rivets, releasing the soft interior away from the metal or the door.
3, You may have to twist off the latch, just like a bottle cap.
4, You will see the wire coat hanger type metal that connects to the latch and locking mechanism.
If you have some grease with you you can also grease up the mechanisms for the lock, lock release, window, mirror.
That's how it is on my Volkswagen.
Good luck, Dave
SOURCE: 1991 Nissa D21 Door Latch broken
There isn't a book or manual detailed enough to show you the inner workings of this lock mechanism. You will more than likely end up damaging the door panel and the mechanism to get the door open. You could go to a junk yard and get a used latch, see how it works, and then jimmy yours open. Or you could buy a new one and do the same thing. Either way the door panel has to come off with the door open and the latch will probably be damaged. There is a little spring that comes off or breaks in the latch and causes exactly what you are describing. There could be other issues as well but it definately needs the latch replaced.
SOURCE: DOOR WON'T OPEN FROM INSIDE OF NISSAN ALTIMA 2002 ON DRIVER'S SIDE
There is a cable that attaches to the inside door latch release handle. The plastic that retains this cable is most likely broken. I have seen this before. If the retainer is not holding the cable sheath correctly, the entire cable moves when the handle is pulled and does not release the door latch.
Remove the door panel and inspect this cable. You will see 2 cables (one is for the door lock). If the plastic is broken, you will need a new interior handle assembly.
Hope this is helpful!!
Nissan Scope Technician- 10+ years experience in Nissan dealership
SOURCE: fuel door release latch not working
Try Super Heavy Duty Lock Tight and attach it to the fuel door. Make small hole to feed the end of spring into then glue it down tight.
SOURCE: 2004 Nissan Murano, back door can't open
I had a similar problem with a sienna and sometimes the cable ( inside the door) between the handle and the latch gets stuck in the sleeve. Kind of like the brake cable on a bike.
take the panel off by removing all the screws you can see on the panel and pull the panel off. There will be plastic pins holding it. Some of them may pop off and some will break off.
Drip oil down the sleeve so the cable slides freely. I used bike chain oil. Do not use WD40. This is **** and will not work for very long. Try the handles a few times before you put the panel back.
SOURCE: Passenger side door will not open from inside or outside.
linkage on inside of door has come undone. take off inside door panel and you will find a small rod that goes to the lock mechanism where the door closes opposite the hinges. follow the handle to the door lock.the nylon bushing may have broken.they are cheap to purchase at auto part stores.
