Hi can you check the model number please and what part of the world are you
Thanks
Rob
You can find the board replacement on ebay just type the model number and you'll find various parts. then by it and ask the same technician to come and fit it for you. there is no power going to the spinner which is controlled by the board.
Check
to see whether power is getting to the washing machine. Is it plugged
in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If
the lid switch is defective, your washer can't spin and may not
function at all. The switch is inside the washing machine main housing
near the door frame. Often you have to raise or open the top or front
of the washer to get to the switch. If it's defective, you need to
replace it.
Some machines have a special lid-switch fuse near
the lid switch, inside the control panel. If this fuse blows, the unit
won't fill with water until you replace the fuse.
The drive
motor may be defective. Many washer brands use a reversing motor. For
agitation the motor runs in one direction, for spinning and draining,
the other. It's possible for a motor to burn out in one direction and
continue to operate in the other. If this happens, you need to replace
the entire motor.
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch
If
your washer has a selector switch on the control panel, make sure the
button for your selection is pressed all the way in, or set properly.
Clutch assembly
Many
GE®/Hotpoint® washers use a clutch and an automatic shift lever. This
assembly is quite complicated. If there's a problem with it, you
probably should contact a qualified appliance repair technician.
Drive motor
Many
washing machines have multiple-speed drive motors. Though it's
uncommon, the drive motor may work fine on one speed but not on
another. If the drive motor has failed on one speed, you need to
replace the entire motor.
best you buy new machine because washing machine repair charge is high so ur mac work in 8 years
it may be the circuit problem.so you send it to a service center.
Appliance Parts from RepairClinic.com
http://www.repairclinic.com/
try this link
http://www.repairclinic.com/RepairHelp/R...
You can get the compitable parts at
Not pumping out the water - if the washer cannot pump out the water, the washer will not be able to spin...check the pump for not pumping.
Door not locking - if the door will not lock, the washer will not enter a spin mode. See if the lock light is lite on the consol.
Broken wires at one of the out off balance switches or a bad switch itself.
A fairly common trouble maker has been a burnt diode on the main control board. See diode R11.
If this has happened to your main control board ( in the consol ) , the wax motor in the door lock assembly is drawing too much hydro and must be replacing at the same time as the control board. The wax motor can check, appear and test ok but will fail when working throughout the cycle.
Appliance Repair Aid does not recommend repairing this board, replacing the board along with the wax motor or the entire door lock assembly is the best way to ensure a proper repair. Some info on the burnt part(s) of the board is linked here if you decide to try to service the board itself.
Hi
This issue needs to troubleshoot your circuit board to find the defective parts.
thanks
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
the technician repeorted that the circuit board is unserviceable and no longer available commercially. Is there an avenue to find a replacement circuit board?
The circuit board has already been assessed as U/S. I would just like to know if there is a site that I could purchase one to replace it.
