I lost the manual with the fault codes
Hello
The
Engine and Automatic Transmission (not applicable to manual
transmissions) in this vehicles drive train are fully electronically
controlled by a computer called the PCM and TCM (Power Train Control
Module, Transmission Control Module). When a problem like this or
other drive-ability related problems occurs the computer stores a
record of the problem (there are of course some exceptions to this,
like the fuel pump, engine coolant temperature sensor and MAF sensor
for instance) in the form of a fault code in its memory, to read
these fault codes you must have the systems memory scanned with a
special tool. Once the fault code(s) are read you then must perform
the appropriate diagnostic testing to find and resolve the problem(s)
DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED
THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT
MAY NOT CORRECT THE PROBLEM. Also always check fuel pressure for
correct spec for your make and engine type.
Have you had the electronic engine control system scanned/tested for fault codes? it will need to be scanned to obtain the fault codes, this testing is key to finding out what the problem may be that is causing the engine to stall. The fault code test can be done free of charge by any Autozone auto parts store, Aamco transmission or Kragen/Oriley auto parts store. Ask for a "OBD2" (on board diagnostics generation 2) fault code test.
