To pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
Thankk u ever so muchh becauseee my mommaaa was totally no helpp (:
Thanks so much!!!!!!!!!!!! Sooooo helpful!!!!
thank you for your help!!!
sweet.. worked first time.. thanks.
WOW! - It worked on the first try! THANK YOU for posting this solution.
Thank YOU!!!!!!! I got this device from my mom after she got a new one. This truly helped!
Read the manual here:
http://www.plantronics.com/media/media_resources/literature/user_guides/explorer230_ug_en.pdf
SOURCE: I replaced my phone and now i cant pair my
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud. Then you may have to enter a connect code (usually 0000) for the pairing to enable. Once they are paired....enjoy!!
Make sure your Plantronics Explorer headset is fully charged and turned off.
Press and hold the call control button (the button on the face of the headset opposite the earbud) for six seconds. When the light begins flashing blue and red, the headset is now ready for pairing with your phone.
Select the Menu on your cell phone. Once the menu is displayed, select Settings, then Bluetooth Menu.
Select the option to add a new device. This will both turn on Bluetooth capabilities in your phone and put it into a setting known as "Discovery mode." The phone should discover your Plantronics headset automatically and display "XXXPlantronics." ("XXX" represents the model series number, such as "320Plantronics.")
Select the Plantronics option on your phone. In many cases, the phone will automatically recognize the headset, but if you are prompted to enter a passkey, proceed to the next step.
Enter "0000" if you are prompted for a passkey. Your headset will flash blue once it is successfully paired with your phone. Once paired, the Bluetooth headset will automatically recognize your cell phone each time it is turned on
Plantronics Explorer 220 Bluetooth Headset Wireless Headset. Cannot connect to new phone.
the same it was paired with the Lg than it wont pair with iphone
how do I pair Plantronics Wireless Bluetooth headset 233 to a new phone?
code
asks for passcode and dont know it
dont have my manual for plantronics explorer 233 new phone wont find it a samsung sgh-a767
Cannot get plantronics back into pairing mode for new phone. How do I reset the headset?
can not pair to blackberry storm! HELP!!
