SOURCE: would like to install 8 sd1446 on a galaxy 99v
Take a look at this page it might help some
http://cbtricks.com/radios/galaxy/dx99v/index.htm
SOURCE: Galaxy 99v off Frequency
it is either a bad soilder on your crystal or your crystal is going bad
SOURCE: My galaxy 959 sqeals and does not receive or
mike has wiring problems. Check for breaks in cord and where the plug goes into the unit. If not original mike then has incorrect wiring for the radio and will need to be changed for config
SOURCE: Galaxy 99V, won't receive but
we can order one or have a pdf one sent to you. just contact us.
SOURCE: frequency counter is running on
You are obviously off frequency. Two things. One does it just cycle 2, 3, or 4 frequencies and then continue to recycle those same frequencies despite going up or down in channels? If this is the case there is a board in the CB called a PCB board. If you open your radio it is a little circuit board. Held onto the side of the radio by a screw and has two or three connectors leading to the board. Replace that little board and your radio will be good as new. I have seen radios come in my shop many times and this is the fix. What that board does is send a signal to the crystals to start mixing a frequency. When it goes out it just sticks where it is at or only mixes a small few frequencies. Here is a link to a place that can take care of you. http://maycomcomm.com/ I trust Maycom with all my new Galaxy parts. Now for the other option. Is it just randomly switching frequencies no matter the channel? We call this oscillating. If this is the case it could be a bad crystal. Could also be a bad PLL. If the CB is Oscillating I recommend you take it to a tech with an oscilloscope to have it repaired. You have to be able to set the mixers and an oscilloscope is the only way. This is the most technical part of the CB (front end)
