Turned closed captions on for the first time. Now can't get them off. Have gone into menu and selected off and they are still on.
Go back and just "look" to see if the captions are still turned off.
if it is still on CC1 or CC2, the captions are still on.
If they are, you must turn captions off and then follow on screen prompts to make sure they are indeed off.
(Did someone turn on the captions on your cable box or other receiver?)
(If they did, this may be the reason that you can/t turn them off on the TV !)
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
SOURCE: tv set
the eprom in the set is probably going nuts , try unpluging for a day and see what happens if it does not clear the problem then tou need anew digital main pc board
SOURCE: Need to turn on closed captions Akai 37
Go into the Menu under audio and navigate to CC and turn it on to Text 1.
SOURCE: I came out one morning and turned on my TV and the
Hi sbsyukon,
Since the solution provided by the earlier expert has been helpful to solve your problem, kindly accept the solution of the first expert.
Thanks for using FixYa.
SOURCE: cannot turn closed captioning off.
Sounds like the CC data is coming from your cable service. I would check your cable box options and turn CC of there as well. what company are you with as far as cable ? also what model cable box do you have?
