Question about Razor 300001-SL Ground Force Go Kart
Razor Ground Force Go Kart will not work.
We have a Razor Ground Force electric powered Go Kart that is a littler over a year old. A few months ago it suddenly stopped working. It turns on but thats it. No movement when the accelerator lever is push forward. Any ideas?
  • 1 more comment
  • Anonymous Mar 22, 2009
    We have a Razor Ground Force electric powered Go Kart. It turns on but thats it. No movement when the accelerator lever is push forward. Any help would be appreciated.
  • Mister White Sep 30, 2013
    Why does my Electric Four wheeled prodcut make a 'clicking' sound ? Select the problem you are experiencing: Rear wheel barely moves. Try the following: Lift rear end up and manually spin rear wheel forward. Should spin 3-4 times with no resistance. If the wheel does not spin freely, replace rear wheel. Battery shows fully charged, lights on throttle light up, unit does not move. Try the following: Remove battery/motor cover to check for loose connection(s). If connections are loose, reconnect them. Secure unit; turn power on & with NO weight on the unit, lift back end up & apply throttle. If rear wheel spins freely, replace the battery and/or charger. Remove batter/motor cover & unplug brake connector from Control Module. Secure unit; turn power on & apply throttle. If the motor engages/rear wheel spins, then replace brake lever If the motor does NOT engage, replace throttle & control module.
  • Guero Soliz
    Guero Soliz May 05, 2018
    My razor go cart starts running as soon as I turn on the switch. What can be wrong?
Replace thumb tab throttle. part is $12.99 from razor. go to razor site to order. i had the same problem after my daughter drove it over a bumpy sidewalk.
Posted on Mar 30, 2009
I have a razor go cart and it not turns on but won't move does anyone have any ideas on how to fix this problem
Posted on Jul 17, 2011
  • Guero Soliz
    On my razor drifter, as soon as I turn on the switch it starts going!! Eat could it be?
    New Friend:
Take a torch an cut into little ***** pieces use for fishing weights or leave it whole take string and milk jug mark your favorite fishing hole also make great anchors
Posted on Dec 09, 2012
Mine does that too just hold the brake down let go and then see if it works!
Posted on Aug 13, 2012
SOURCE:
Razor ground force go cart
I don't think this would be a problem, as long as the wheels fit the axle properly, both in diameter, and length of shaft.
Aug 24, 2014 | Razor 300001-SL Ground Force Go Kart
Tip
Gas Engine Conversion
Just converted our Razor Kart to a 49cc gas motor. Is twice as fast as the electric version but was very unstable with the stock wheels. I went with 4" slicks and is much better. Transplanted the drive train from a pocket bike with electric start and speedometer. Was a 2 day project and was well worth the time.
on Sep 12, 2009 | Razor 300001-SL Ground Force Go Kart
Repair
this unit may take several hours to charge correctly
May 21, 2013 | Razor USA Razor Ground Force Drifter Go...
Razor ground force battery says its fully charged but gokart wont turn on
Here is the owners manual for the future (in case you don't have one.)
http://www.meijer.com/assets/product_files/pdf/1000422_groundforce_manual.pdf
It sounds like the push button fuse next to your charging plug. Push that in and try again. Otherwise it could be a wiring defect.
Aug 19, 2012 | Razor 300001-SL Ground Force Go Kart
My son's ground force drifter is showing a charged battery but will not go. I see the full charge lights on the throttle but it when i depress the throttle, it does don't move. Anythought? Thanks
If the battery is gone(bad), sometimes it will show fully charged (volts are good).. but it has no amperage to "push" the voltage... It takes amperage to make the drifter move... (time for a new battery)... they don't last long...
Aug 03, 2011 | Razor USA Razor Ground Force Drifter Go...
Go kart doesnt run anymore wat could the problem be
Wire connection seems to be the problem with any electric dependent vehicles of that sort. They are usually cheap so the wireing is cheap as well. Check to see if there is any loose wires or even some cuts in the wire. Repair them if so. If not that...make sure anything that likes too dirty than what you think it should be...clean it off with a can of compressed air (don't put water on that sort of stuff). Keep checking around the kart and check for anything out of the ordinary and work from there.
Hope this helps ^_^
Jul 19, 2011 | Razor 300001-SL Ground Force Go Kart
The lights are on showing that it is charged but will not go. It is only 10 months old.
If the charger is left plugged in longer then 24 hours you may over charge the batteries and they will not work properly. Also You must charge the batteries once a month even if it hasn't been used.
Lift up the back end of the gocart and see if the wheels spin when you pull the throttle. If you only get a clicking sound start by replacing the control modulator. 10 months old your batteries should be still good unless you over charged them. (Leaving plugged in longer then a day) Good luck...
Nov 16, 2010 | Razor 300001-SL Ground Force Go Kart
Hello, I have 2 of these and they just stopped working, slight clicking sound but need help!
If your batteries are good and are putting out the proper voltage I would say your control mod has failed. Usually all the lights work but all you get is a faint clicking sound everytime you turn the throttle.
Oct 12, 2010 | Razor 300001-SL Ground Force Go Kart
Razor 300001-SL Ground Force Go Kart Logo
7,238 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
