SOURCE: canon pixma ip1880
check the position of the cartridges, maybe you put it in the wrong position?
SOURCE: BAKIT PO AYAW MAG DERETCHO
Hi
Check first if you can do a self test print on a stand alone not using a computer with out any problem, if its ok then try to reset the spooler by going to the windows services, click on start then run then type in the bos services.msc then look for the print spooler. try to stop and re start, if the problem still exist, uninstall and re install the driver of your printer. if problem still persist then there is a problem on the services of your windows operating system
SOURCE: paano mag-install ng epson rx530
hiram ka ng PC na may CD ROM tas i copy mo ung laman sa USB. tas ilagay mo sa PC mo then run the setup to install. or mag download k nlng ng driver. try mo hanap ng mga driver sa www.cnet.com
