It has leaked on frooze all items around it and the ice make will fill with water but only leaks water
From what you have described it sounds as if the water line connection is not solid and secure to the ice maker. If it is leaking water and freezing surrounding items even more that would need to be addressed by a professional if you cannot find any issues yourself. You can try to turn the ice maker off, if it is equipped with a shut off arm or switch, and then look for any issues. You may also want to clear the freezer of items in that area and watch where the leak and new ice form to pinpoint the faulty area(s). Please let me know if you find anything additional out or if you need more help. Good luck!
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
SOURCE: FRIGIDAIRE SIDE BY SIDE WATER LEAKING FROM BOTTOM OF FREEZER DOOR
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) }
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
First lets decide where your leak actually is.
Areas to consider:
This is mostlikely a stopped up drain pan. A cold area that is not suppose to be cold likewhen you have a freezer coil that is suppose to be defrosting and is not... Seebelow for a more complete ideas list of things to check under Possibility.
The drain pan drain line is themost common. Inspect it and repair as needed, maybe its just a wrapper over the exit hole of the pan.
Some more Possibility's:
1 There is a drain that carries away the water under the cooling coils. Thesecoils are in the freezer section. Its most likely clogged or froze up.
2 The ice maker could be letting water leak all the way down look for an icy trail from the ice maker area.
3 Door gaskets are not sealing especially on the bottom of the door. Thisallows warmer air into the fridge section and it is condensation on floor underthe crisper.
If you check all of these items and still cant find it please post back andtell me what you did find. So I can help you more. Please rate me as much aspossible as Im trying to keep my average up and do the things that willactually educate and help people.
THANK you for using fixya and good luck..
SOURCE: Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
SOURCE: freezer leaking
your drain is probably plugged with something take tha back off of the freezer and find the drain .... let me know what you find out...
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
My Frigidaire model FRS24ZGE leaks water from the bottom of the freezer door after using the water/ice dispenser. Any ideas on a fix?
