Question about Mercedes C-Class Exterior Pillar Posts Trim Set
No power to fuel injetor - Mercedes C-Class Exterior Pillar Posts Trim Set
  • Chris
    Chris Dec 01, 2013
    Do you mean fuel Pump? The fuel injectors themselves do not have power. Could it be you mean Throttle Positioning Sensor?
    New Friend:
  • 22 Answers
Hope this Helps-
Posted on Dec 01, 2013
SOURCE:
How do I know why my fuel won't get into injetors?How do I get a diagram for wiring from fuel tank to fuel injetors?
Hello Monica, that is a wide area to cover ,so you can go to auto zone site and log in (its all free) go to (my vehicle)in put info then go to (repair guide) then to sub catagorys there are a few including trouble shooting. check pressure regulater and or vacuum supply to it as well, you should have a test port next to it or near, test it with a pressure gauge to see ,pressure should be 35+ pounds . i really hope this helps you ,if it does please let me know
Woody
Sep 27, 2014 | 1993 Toyota Pickup
Hi i am not sure were to go from here i have a rodeo 1997 turbo diesel lx ,it wot start now i have looked at fuel i have checked and tested the glow plugs they are fine iialso dod a moanual test with the...
remember the 3 components fuel, fire and oxygen, if the fuel is coming then its the fire because if there was spraying gas and there was nothing it got to be the fire.
Jan 07, 2014 | Cars & Trucks
Wire diagram for the fuel injectors on a saturn sl1
firering order should be on in take manofold fuel injector are in harness should only fit on one way
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Aug 31, 2012 | Saturn SL1 Cars & Trucks
Starting problem have fire and fuel but still wont start changed pick up coil and ign module
If thats a TBI system..pull the duct work off and see if the injector is flowing a good stream of fuel while you turn it over..Ive seen fuel pumps run and fuel come from the line but not enough flow to make the injetor flow..
Sep 04, 2011 | 1996 GMC Sierra
1997 grand prix very ruff idle no power changed cps and checked injetors and fuel pressure was 46-50 psi. have great spark to all cylinders
Rough idle and no power, it could be the mass air flow sensor, or even an intake leak (vacuum). Either one I would not put passed an engine of its age. I hope this helps point you in a helpful direction. Let me know how it goes and which motor you have as well.
Nov 06, 2010 | 1997 Pontiac Grand Prix
It stalls while driving.new air and gas filter installed ?
Could be dirty fuel injectors or some water in your fuel. STP fuel injetor cleaner or HEET water remover on next full tank of gas should solve this. Use one or the other not both
Sep 06, 2009 | 2003 GMC Sierra 1500
99 Ford Ranger flex fuel with plugged fuel injector
They would need to be removed cleaned and bench tested.Considering the age of the vehicle id be suprised if it was an injector What are the symptoms your experiencing
Oct 18, 2008 | 1999 Ford Ranger SuperCab
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
64 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
